586,913 active members*
2,931 visitors online*
Results 1 to 9 of 9
    Nov 2003
    634
    Automatic toolchanger
    Has anybody built this toolchanger?
    http://home.insightbb.com/~joevicar3/default.htm
    I can see benefits to adapt this idea to a router type machine and spindle.
    May 2003
    267
    I have not built one yet. How about a different approach to tool changing. I saw one professional cnc machine where all the tools where on one of the sides of the table. The machine spindle has to move to one of these tools to pick it up. This seems a much easier setup. Any ideas on how to get this to work?
    4826
    What you suggest is perfectly feasible, George, but those tools are retained by the retention knob system. This means you would have to build your own spindle, because you need through the spindle access for the drawbar mechanism. This is not handy for the guys using a commercial router for a spindle. But, it could be done.
    Nov 2003
    79
    can someone explain for my sake exactly how the tool changers on production cnc machines work?
    Nov 2003
    108
    Does anyone know how the Sears/Crafstman Quick Change collet for the Porter-Cable routers actually works. Would that be a good candidate for a tool changer.
    Jeff (Davis) how do your collets works.
    best Regards
    Phil
    4826
    Yes we had a thread discussing this not too long ago:
    http://www.cnczone.com/showthread.ph...eville+washers
    779
    I don't believe that these collets hold a tool in a known position.
    My collets do hold the tool in a fixed length. This is the benifit of automatic tool changes. You don't need to stop the code to fix the Z tool length. But like Hu said, we router users can't use the draw bar method of holding the fixed tooling.
    I feel that using tooling like what I designed is the best option for router users. When its time to change the tool, my router shuts off, and this is what I hear when I'm away from the router.
    Jeff Davis (HomeCNC)
    http://www.homecnc.info
    May 2003
    267
    I found a web site that has a tutorial on tool changers at:
    http://jjjtrain.kanabco.com/vms/mill_tool_holders.html
    May 2003
    267
    Here is a picture of the retention knob. I am still learning about tool changers. Found a good tutorial at:
    http://www.servoproductsco.com/html/sam_7_cnc_atc.html
  1. Miniature Automatic Tool Changer
    By jwvica01 in forum News Announcements
    Last Post: 02-18-2013, 09:03 PM
  2. cincinati toolchanger
    By cyclestart in forum Uncategorised MetalWorking Machines
    Last Post: 05-23-2005, 09:22 PM
  3. Miniature Automatic Tool Changer
    By 1ctoolfool in forum News Announcements
    Last Post: 04-18-2005, 11:56 AM
  4. Automatic Pallet Changer
    By DDM in forum Community Club House
    Last Post: 10-07-2004, 04:22 PM
