586,055 active members*
4,424 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > electrical problem with stepper motor and ac spindle motor
    Jun 2012
    11
    i have a 3 axis cnc wood router
    when i start spindle motor the step motor also start random rotation and axis moves unnecessarily with large noise and vibration
    probably this may be due to loading effect of spindle motor on stepper drive
    or may be loading on driver controller card.
    but what is probable solution of this problem??
    pls help
    24221
    Re: electrical problem with stepper motor and ac spindle motor
    Most often grounding and/or bonding problem, make sure the spindle frame is grounded properly.
    http://www.cnczone.com/forums/phase-...se-issues.html
    http://www.automation.siemens.com/do.../emv_r.pdf?p=1
    Al.
    Albert E.
    May 2005
    1397
    EMF. As Al says, grounding is key. Also make sure your step and direction cable is good quality (fat wires), short, and away from everything else. Shielding, even rapping a ground wire around the step-direction wires, is a last resort.
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
  1. spindle motor to heavy for the stepper motor...
    By paulosousa in forum Community Club House
    Last Post: 01-07-2014, 02:11 PM
  2. Electrical connector for Japan Servo KT60LM06 stepper motor
    By jsteveb in forum Stepper Motors / Drives
    Last Post: 01-03-2014, 02:02 AM
  3. Replies: 0
    Last Post: 02-26-2013, 08:37 AM
  4. Stepper motor as a spindle motor
    By Arich0908 in forum Benchtop Machines
    Last Post: 04-12-2010, 06:39 PM
  5. Spindle and Stepper Motor Oscillation. Is it a Problem
    By pzzamakr1980 in forum Tormach Personal CNC Mill
    Last Post: 02-28-2010, 02:57 AM
