586,051 active members*
3,824 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 18i-MB parameter write protected
Results 1 to 8 of 8
    Jan 2015
    please help have had to do a memory clear on my T21i-D so now need to re enter my O9000 programs
    I have changed PWE to 1 then turned off and back on again but when I try to change parameter 3202 bit 4 (NE9) from 1 to 0 I get a WRITE PROTECTED alarm
    how do I get over this
    Jun 2004
    511
    Re: Fanuc 18i-MB parameter write protected
    I have changed PWE to 1 then turned off and back on again?
    Put PWE to one and just leave it on, you must be in MDI to edit parameters. Some machines also need to be in Estop.
    Jan 2015
    thanks ifixcnc the book says after changing PWE to power of and on
    still no joy
    Jun 2004
    511
    Call Fanuc Tech Help 1-888-326-8287 they should know what to do. I have dont have a 21i-D
    Jan 2015
    sorry located in the UK
    Jan 2015
    Put the emergency stop and then you try to change the parameters.
    Aug 2011
    2517
    leave PWE on 1 and DO NOT power off. if you power off, the machine will re-set PWE to 0.
    Set mode to MDI, Set PWE to 1, change the parameters then after you have finished, power the machine off then on.
    2932
    1. MDI - Settings - PWE=1 (Alarm P/S100 flashes as warning that PWE is ON... you can ignore this).
    2. System - PARAM - key in 3202, press [NO. SRH] - cursor over to bit 4 and set it = 1.
    3. Go back to Settings and turn PWE = 0, then RESET to clear the alarm - no need to power off.
    Re-enter O9000 programs.
    After you've finished, repeat steps 1, 2 (set 3202 bit 4 = 0, and 3 - still no need to power off.
  1. Replies: 4
    Last Post: 06-06-2023, 04:27 AM
  2. Replies: 3
    Last Post: 08-22-2014, 08:13 AM
  3. Replies: 3
    Last Post: 04-16-2012, 06:12 PM
  4. write protected dwg
    By smudger in forum Autodesk
    Last Post: 09-05-2007, 08:26 PM
  5. write protected
    By stevieboy in forum Autodesk
    Last Post: 06-03-2004, 09:03 AM
