586,089 active members*
3,755 visitors online*
    Jun 2013
    29
    Reduction with pulley and belt synchronized.
    Hello,
    I'm working on retrofit of an oxyfuel cutting machine and need to do a reduction with pulleys and belt synchronized.
    I would like to know how timing belt pulley size and synchronized to make a reduction of 5: 1.
    24221
    Re: Reduction with pulley and belt synchronized.
    What system are you using for the retrofit?
    Is the encoder etc on the motor or the final drive?
    It is usually just a case of scaling the feedback element/resolution to whatever the final resolution is?
    Al.
    Albert E.
    Jun 2013
    29
    Al.
    Thanks for your quick response!!!
    I'm new to cnc machines, for this I don't know tell you some data.
    This machine I'm logging the retrofit is a machine that worked with mcpe photocell as you can see in the attached images.
    To perform the retrofit plan to use the Mach3 with two drivers and two motors DQ542MA 57BYGH115-003B do one for the x-axis and one for the y axis with rack and pinion.
    I don't know how much resolution to inform would be a good resolution?
  1. Belt Reduction
    By BBR in forum Mechanical Calculations/Engineering Design
    Last Post: 10-28-2011, 01:31 AM
  2. ballscrew pitch vs. gear/pulley reduction
    By Hans_G in forum Linear and Rotary Motion
    Last Post: 06-22-2009, 07:12 PM
  3. Slick Belt Reduction ! ! !
    By CNCCajun in forum Waterjet General Topics
    Last Post: 04-24-2009, 06:02 AM
  4. timing belt reduction
    By drwc in forum Benchtop Machines
    Last Post: 05-23-2005, 09:31 PM
  5. Belt reduction questions Please help!?
    By Bird_E in forum Uncategorised MetalWorking Machines
    Last Post: 11-26-2004, 02:55 PM
