pasted from other thread
A method to estimate and quote costs to a owner would be the setup and run method.
You can detail a cost estimate for the setup and quote based on that.
Example:
Setup cost
design widget 100$
cam widget 100$
tooling for widget 100$
fixtures for widget 100$
material per widget 100$
make 1 widget 100$
Total cost for setup $600.00 and 1 widget complete.
All widgets after that can be quoted at cost of time and material only, no setup. or 200$ as example details.
Of course this is one time and if the customer needs more at later date. You would revise proposal and deduct design and cam cost for that run of widgets.
And included all other setup costs to start that run.
Then the cost per each widget can be quoted like before.
Another estimating method to consider I can write books on this subject!
Also a couple notes from a professional estimator with a lifetime of experience!
The detailed and professional proposal / quote always gets considered. "might not get job but they will read and consider not skip or trash it"
Never be afraid to detail your costs, A company in business has same costs as you do!
From my life time of experience we always looked for professional work that is done correctly and on time "not always low bidder"
Over time a business wants relationships with builders, designers, fabricators ............ that they can count on to do it and do it right and on time.
If all they want is low bid, most the time its best to move on to other work or clients!
just my opinion!
md
