586,036 active members*
3,617 visitors online*
Page 3 of 4 1234
Results 41 to 60 of 65
  1. #41
    Apr 2014
    215
    Re: UCCNC Macro sharing
    audiokiller,
    I believe there are two methods available... one is available now (using variables or vars#) and the other which "should" be in the next release can have a popup to ask the user for input, either as a string (text) or a double (number)
    The first method, if you have a look at pdf page 51 of the current manual (parametric programming) it explains variables and using vars#.
    http://www.cncdrive.com/UCCNC/UCCNC_usersmanual.pdf
    The way that I prefer is the message box popup (as I don't have to remember to store the vars in advance of me running the macro code.....)
    The following is extracted out of the current development version of uccnc "macro_capability_detailed.htm file within the uccnc documentation folder.
    Function: string TextQuestion(string Questiontext)
    Description: This function shows a Question form waiting for a string as the answer. The text of the question shown on the Form is the parameter.
    Example: string val = exec.TextQuestion("Stop code execution?");
    Function: double Question(string Questiontext)
    Description: This function shows a Question form waiting for a double value as the answer. The text of the question shown on the Form is the parameter.
    Example: double val = exec.Question("What X position to move?");
    If you are running the vars# method, you could put an if statement in the macro to check the current vars# saved is set or have a simple dialog box popup with a yes no question to ask if you've set the vars already (if you have a look at post # 25 in this thread you can see some code I posted which uses the yes/ no messagebox query and you can customise it as required).
    Rob
    Rob
  2. #42
    Sep 2005
    1195
    Just curious, can we run uccnc software with any hardware or only run with uccnc hardware product. So that we can replace mach3 with this uccnc software on the same hardware. Thanks.
  3. #43
    Apr 2014
    215
    Quote Originally Posted by asuratman View Post
    You must buy a uc motion controller (uc100 (usb), 300 (usb or Ethernet) or 400 (Ethernet)).... uc300eth is not released yet.
    Uccnc will not work with parallel ports or any other motion controllers.
  4. #44
    Sep 2005
    1195
    Thanks for reply. How about post processor, are they available for many software?
  5. #45
    Apr 2014
    215
    For the most part, I'd say you could use the mach3 post processor... it depends there are a few extra m codes for plasma.
    What software do you use?
    Rob
  6. #46
    Sep 2005
    1195
    I want to use fusion360.
  7. #47
    Jul 2015
    11
    Quote Originally Posted by robertspark View Post
    audiokiller,
    Rob
    Rob
    Thank you very much Rob, I will try this and report the result =)
  8. #48
    Apr 2014
    215
    Sorry I've not used ad360 before, if it has a Mach post processor I would have thought it would be fine.
    Rob
  9. #49
    Nov 2006
    40
    I've used Fusion a little and found the "cncrouterparts.cps" post worked fine for what I did.
    It is a modified Mach processor..
    Mark
  10. #50
    Sep 2005
    1195
    Thanks for the info.
  11. #51
    Jul 2015
    11
    In the latest version of UCCNC 1.2022
    This command not longer works... =(
    Why they have to take out this command???
    Quote Originally Posted by vmax549 View Post
    This will write a string to a file 1 line at a time. IF there is NO such file it creates it and IF there is a file it appends to it.
    // Write one string to a text file.
    string text = "X" +AS3.Getfield(226) + " , Y" + AS3.Getfield(227) + " , Z" + AS3.Getfield(228);
    System.IO.File.AppendAllText(@"C:\uccnc\Probe1.txt ", text+ Environment.NewLine);
    THIS is what the file looks like after 3 probes and writes
    X0.2000 , Y1.9500 , Z-0.6700
    X0.8100 , Y2.7550 , Z-0.1950
    X1.7450 , Y2.4950 , Z-1.2800
    Hope that helps , (;-) TP
  12. #52
    Oct 2005
    1145
    THose are all UCCNC and C# function calls and they are still there. BUT there is a new function that will auto record the probe trip values #5061-5066.
    M40 turns it on
    M41 turns it off.
    You set it all up in the TOOLS /PROBE page.
    Please read the manual (;-) TP
  13. #53
    Jun 2015
    943
    Quote Originally Posted by audiokiller View Post
    I just tested this code on the 1.2022 an it works.
  14. #54
    Jul 2015
    11
    Thank you for your answer vmax549, i will read the manual =)
    Im recofiguring my stepcraft profile to test this new settings, my profiles dont have this new screen, but the command dont work anymore, i have a macro that write the values to a file, the macro run but no values are written, or I have to turn it on the writing with the m40 first?
    M40 turns it on
    M41 turns it off.
  15. #55
    Jun 2015
    943
    Yep, M40 turns it on after collect points with G31 and save the points to file with M41 code.
  16. #56
    Sep 2005
    1195
    How do you guys learn to program macro? Are there any training materials.
  17. #57
    Macros are written in C#, so you need to learn C#.
    But if you've done any programming in Basic or VB, you can probably pick it up pretty quickly by looking at the included macros. There are lists of functions in the UCCNC\Documentation folder.
    Google helps me when I get stuck.
  18. #58
    Sep 2005
    1195
    installation folder of the UCCNC software /macro_capability_detail
    Do I need to learn all C language or just instruction on above folder ?
  19. #59
    That depends on what you want to do.
    The UCCNC docs only cover UCCNC functions, so you,ll need to know a little more.
    As I said, if you study the included macros, you'll learn a lot of what you need.
  20. #60
    Apr 2013
    1899
    Programming is a trade. Some people go to university, some learn it at home in their spare time to a level which satisfies them. Anyway, a good start is reading a book or two about programming in general to get a basic understanding. UCCNC macros are written in C#, which is basically C, which in turn is a programming language. So, if you know C it is easier, but if you know Basic, Cobol, Ada, Java or any other other programming language than you should not have a steep uphill. If you never programmed then it may not be very easy, but all depends on your own capacities.
Page 3 of 4 1234
  1. UCCNC owners and support thread
    By shorton in forum UCCNC Control Software
    Last Post: 08-25-2017, 12:07 AM
  2. Getting Started with UCCNC Software
    By BanduraMaker in forum UCCNC Control Software
    Last Post: 02-08-2015, 07:06 PM
  3. UCCNC software released for sales
    By dubble in forum News Announcements
    Last Post: 08-05-2014, 11:25 AM
  4. UCCNC software release
    Last Post: 06-13-2014, 02:24 PM
  5. Sharing a tool offset verification macro
    By dpuch in forum Parametric Programing
    Last Post: 08-02-2010, 09:46 PM
