586,912 active members*
3,428 visitors online*
    Dec 2020
    5
    Enable limits during homing UCCNC UB1
    When homing the signals from the limit switches are not considered.
    Is there a way to enable this?
    Reason is I'm doing a upgrade of an old mill which has +/- limits separate from home switches (located some 1/3rd between limits). If the machine is on "wrong" side of home at start up, it can crash during homing procedure.
    Ideally hitting a lim during homing should make the direction change to reach home signal.
    I could solve this by using the lim as home, but thought I might ask for other solution first. Having home 1/3rd between limits makes homing faster with less transport.
    Im using UCCNC with a UC300eth UB1.
    Jan 2018
    1516
    Re: Enable limits during homing UCCNC UB1
    That's an interesting issue. You'd think the machine would know which side it was on and move accordingly. ie: the shortest direction back to home without going near a limit switch.
    I have no solution for you but I am updating to the 300 and uccnc soon too.
    I'll have a good read through all the uccnc stuff tonight and see if there is anything mentioned for a resolution.
    Dec 2020
    5
    Thanks.
    Before homing the machine has no clue as to where it is, at least not on such a system (steppers with encoders "hybrid servos". The direction for homing can be set, but that does solve the problem.
    Dec 2020
    5
    Threadlift of the week, I know but still; no input for a better solution enabling the lim sw during homing?
  1. UCCNC + UB1
    By mabencomo in forum UCCNC Control Software
    Last Post: 10-31-2019, 09:41 PM
  2. UB1 - UC300-ETH - UCCNC not dancing yet
    By rcmcdee in forum UCCNC Control Software
    Last Post: 09-07-2018, 02:20 AM
  3. PMDX-109 with UCCNC UB1
    By bobmagnuson in forum UCCNC Control Software
    Last Post: 08-02-2018, 12:59 PM
  4. Not getting any input from PC to CNC Router - UCCNC UC300ETH UB1
    By crash416 in forum DIY CNC Router Table Machines
    Last Post: 11-03-2017, 12:49 AM
  5. Setting up Config >Homing/Limits Dialog (Motor Home/Soft Limits)
    By CStevens6 in forum Mach Software (ArtSoft software)
    Last Post: 07-18-2013, 04:19 AM
