Hi All,
hoping you can point me in the right direction
I have built my own machine and done a little testing on a few bits a pieces and today I tried to mill my first real part but I am having a little issue
The part is simply a 50mm square with three 6.5mm holes right through, my issue is that as soon as the machine starts one of the holes it just about grinds to a halt as the feed rate drops down to about 0.60
I think the way I am setting up the tooling may be wrong as if I have a square pocket the machine runs fine but as soon as I try and do a pocket that is a circle the feed rate drops down to almost nothing?
is my problem the fact that I am trying to do a hole as a pocket?
Cheers
