KL-1325 CNC Machine with vacuum table 98.4 inc x 51.2 inc
More info here
http://www.automationtechnologiesinc.com/products-page/cnc-router/kl-1325-cnc-machine
KL-1325 CNC Machine with vacuum table 98.4 inc x 51.2 inc -
Brand New CNC Router Engraving Machine with vacuum table, Mach3 Controller,
3 KW Water Cooled Spindle + 3KW 400Hz Variable Frequency Driver
You can come to our show room to check the machine.
We Changed this Machine to Mach3 Controlled System.
X, Y axis working area: 1300mm*2500mm (51.2 inch x 98.4 inch)
Z axis working area: 150mm ( about 6")
Table size: 1440mm*3000mm
Max. speed: 14m/Min
Max. working speed: 12m/Min
Working accuracy: 0.01mm
Repositioning accuracy: 0.05mm
Feeding height: 120mm
Command code: G code
Software: Mach3 software Demo with Windows 64,32 bit
Working power: 5000W
Working voltage: AC220V/50HZ/60HZ
Spindle power: 3 KW
Spindle running speed: 0-24000
Mach3 Controller with Mach3 Demo Software
Spindle Power Motor: 3KW, Water-Cooled, ER20 Collet Chuck
Spindle Speed: 0-24000 rpm With VFD, AC220V/50Hz/60HZ
X, Y, Z axis driver: Stepper Motor Driver, NEMA34 Stepper Motor: 920 oz-in
X, Y Z Limit Switch
6 Axis Breakout Board Optical Isolated
E- Stop
X Axis: 20mm Linear Rail with Rack Pinion
Y Axis: 20mm Linear Rail with Rack Pinion
Z Axis 20m Linear Rail with 25mm Ballscrew
One year USA parts Warranty
Shipping fee is for USA
List Date: 2/4/2015
For more info, click here to view the original listing: KL-1325 CNC Machine with vacuum table 98.4 inc x 51.2 inc
On Sale For: $11,999.00 + $990.00 Shipping
Mobile friendly version: KL-1325 CNC Machine with vacuum table 98.4 inc x 51.2 inc
