586,106 active members*
2,984 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > OMNI 1325 or CRP 48x96 - which should I buy?
    Dec 2014
    16
    I am considering purchasing either an OMNI 1325 or building a CRP 48x96. I am new to the CNC world but I have narrowed it down to either of these two options as a good place to begin.
    I am leaning strongly towards the OMNI, but I will have to bring anything I buy through either my front door (34 inches across) and maneuver the router through my house into the workshop, or through the workshop door which is 31". I would greatly prefer to have the OMNI because it seems to me like it will be more rigid than a CRP build.
    I will be using this router to do heavy duty cutting cycles of aluminum, wood, and plastics, so I need something that will be very rigid and reliable.
    So I have two questions. Which machine do you all think is the stiffer, more robust router, the OMNI or the CRP?
    And the big question is this; will I be able to get a 1600KG CNC table turned sideways and then brought through my doorway in order to get it into my house!? OMNI has told me that they will ship the gantry unattached so that I can assemble the whole thing later once it is inside my house. So I will need to be able to bring just the table through my doorway (the table is .5 Meters high) in order to make this work. Thoughts from everyone? Do you think I could use a couple of engine lifts to achieve this? Or maybe I could hire a team of professionals to get the job done?
    Jamie
    Nov 2013
    143
    Re: OMNI 1325 or CRP 48x96 - which should I buy?
    I don't have the answers to all of your questions, but I do know that CNCRP will ship the machine setup in separate packages, so you can put the machine together yourself. This will allow you to get it through any door you have.
    Also, you can modify the CNCRP machines to achieve any rigidity you like. They sell tons of parts, and you can make your own if you like (like I did).
    CNCRP's support is friggin amazing.
    I don't have any experience with OMNI, so I cannot answer any questions you have about them.
  1. OMNI 1325 Ordered
    By swarfmeister in forum Chinese Machines
    Last Post: 10-28-2016, 08:14 AM
  2. OMNI-CNC 1325 on its way!
    By Jzarski in forum Chinese Machines
    Last Post: 10-28-2016, 08:09 AM
  3. 1325 machine ordered from Omni cnc
    By jbobrout34 in forum Chinese Machines
    Last Post: 08-22-2015, 02:38 AM
  4. Replies: 12
    Last Post: 02-02-2015, 11:52 AM
  5. New Machine Build from Omni CNC 1325
    By tcmartin61 in forum Omni CNC
    Last Post: 11-29-2014, 03:57 PM
