I have searched here and watched his videos. Looking to see how to wire this into the breakout board. Tweakies website mentions that the Bob can power this, I have outputs available (pin 14 for example outputs 5v). I'm at a stand still. Please help.
Goto your spindle tab on pins and port, look down and find the spot to "un check" disable flood relay, then look and see which output to use ,then go back to output tab and go down till you find that output and "check it" . Pick a pin from the list below. Make sure you save everything.
I just order a relay to do the same thing, but I think the laser I ordered use 3Vdc. I will be using the 5vdc to trigger the relay.
OSD
ps. You have 6 outputs to use and a about ten pins, just make sure you keep track
Perfect, I'll give that one a shot also tonight. Thanks for the info on both issues.
NO problem! I know how frustrating all this can get, being a "newb" myself.
OSD
This one worked out great. On to the tool zero.
Thank you for your help.
