586,688 active members*
2,472 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > TB6560 stepping motor driver and 5 AXIS CNC interface board
    Feb 2015
    Dear friends, I am new at this and I am still trying to understand u lot of things so if anyone could help me I would appreciate it a lot.
    I need to connect TB6560 driver to a 5 AXIS interface board but I don't fully understand the schemes i found on the internet.
    Also is it necessary to get voltage (12V) on both driver and interface board or not, since the interface board is connected through USB and is recognized even without 12V. So if anyone is willing to draw the lines how to connect this or just maybe explain it to me I would be very grateful.
    Attachment 267528
    1695
    Re: TB6560 stepping motor driver and 5 AXIS CNC interface board
    Based on what I see in the photo, there are two ways. One might work better than the other, so try both.
    Method 1
    Connect all three driver "+" pins to the interface 5v
    Connect the three "-" pins to their proper pins on the interface
    Method 2
    Connect all three drive "-" pins to the interface ground
    Connect the three drive "+" pins to their proper pins on the interface.
    In both cases, don't forget to connect the usb so that there is power.
  1. Problem with CNC 4 Axis 3.5A TB6560 Stepper Motor Driver Board
    By bbbharvard_cnc in forum CNC Machine Related Electronics
    Last Post: 04-10-2012, 06:11 AM
  2. 'New' 4 axis TB6560 stepper motor driver CNC controller board
    By Doronby in forum Stepper Motors / Drives
    Last Post: 02-22-2012, 04:29 PM
  3. 4 Axis TB6560 CNC Stepper Motor Driver Board Controller with a GGC usb
    By RCjunkie in forum CNC Wire Foam Cutter Machines
    Last Post: 01-24-2012, 04:45 PM
  4. CNC stepper motor driver board TB6560
    By Chaparro1973 in forum Spanish
    Last Post: 12-27-2011, 07:00 PM
