For a DXF 2d drawing Is there a way to select a whole object and join gaps? Or do you just have to zoom in and find every little one and use "join line"
No,
You need to join where gaps are. Do a chain selection and where the selection stops is your gap. You could join with lines or you can use trim extend.
Al DePoalo
Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
To the OP,,the file you had uploaded originally,here it is with planar.
Ok thanks Al, just wanted to be sure I wasn't doing it the hard way
