I recently tried to add a fourth axis to my Mach3 system and a problem has developed that is driving me crazy;
This is Mach3 which has been running 3 axis for past few years, everything was good to go, but when I added the new motor same kind as the other 3 wired exactly the same way.
With 4 motors connected to the G540 it will not come out of Fault mode, disconnect the a axis it immediately goes green.
all 4 motors hooked up…. will not come out of fault
All motors hooked up and unhooked while turned off turned off
with any three motors hooked up, tried the new A motor in one of the other connectors… immediately goes green upon start up
tried turning off a axis in ports and pins.. with 4 motors still
connected still in fault
tried switching motors to different connections… same condition
with only 3 motors in any different order.. works fine
as soon a I add the fourth motor in any spot it will not come out of fault
Do I have a G540 problem or a mach3 problem or a computer problem? At this point I am just confused and cannot figure this problem out.
Any help would be appreciated
Jack
