586,104 active members*
3,331 visitors online*
IndustryArena Forum > CAD Software > Solidworks > negative of a solid in solid works
    Feb 2015
    7
    OK I am a newbie so bear with me I have a solid file I want to turn into a negative to use as a fixture to to hold the part when I go to machine the second side is this possible
    Jun 2008
    562
    Re: negative of a solid in solid works
    You have to run the "cavity" routine. Its in the mold tools area. See the help menu, there are a couple of steps to go through.
    Mike
  1. Solid works to DXF
    By Rik H in forum Solidworks
    Last Post: 06-06-2013, 02:57 PM
  2. Replies: 0
    Last Post: 05-01-2013, 05:00 PM
  3. Solid works
    By dnelso in forum BobCad-Cam
    Last Post: 06-02-2009, 03:38 AM
  4. just got solid works
    By bearracecars in forum Solidworks
    Last Post: 08-02-2007, 05:25 AM
  5. Which came first, Solid Edge or Solid Works?
    By Arnie in forum Uncategorised CAM Discussion
    Last Post: 09-15-2004, 12:25 PM
