Hy,
Could anyone help me with some info about 4-th axis machining tips?
We run a HULLER HILLE NBH 5 WITH FANUC 21i MB CONTROL. My problem is that for a program with B axis movement it stops after each code line, the code was generated with RhinoCAM 2.0, from which I have used only the movement part of the program and as a header i have used the sequence that we always use.
O6100 (TEST CAMA)
G10 G90 L2 P1 X0 Y0 Z0 B0 (G54)
M6 T3
M171 K1
G0 G80 G90 G94 G99
G17 G40 G49
G0 G54 X0. Y88.8168 S1000 B0 M3 M8
G43 H1 Z50
G0 Z44
B-161. F100
G1 Z41.1503 B-161. F70.
Y86.9973 B-164.1 F50.
Y85.1777 B-167.2
Y83.3582 B-170.4
Y81.6251 B-173.3 F40.
Y80.8622 B-177. F400.
Y80.0993 B-180.7
Y79.3365 B-184.4
Y78.5736 B-188.1
It stops as ''SINGLE BLOCK'' was activated and I need a smooth movement.
Is there a M-code ore G code for this problem of which I am do not know about.
Thank you!
