586,069 active members*
3,247 visitors online*
Results 1 to 8 of 8
    Jan 2004
    185
    MORI SEIKI SL3 TURRET PROBLEM
    Hope someone can help, when asked to index to next tool the turret moves forward but does not index, we have fitted 2 new relays (my4 24v) to lower part of rear control panel also the green light stays out until I switch off and reset power to machine. before this happened it was working fine until it started indexing without stopping or pressing the index
    thanks
    BR
    Feb 2009
    6028
    Re: MORI SEIKI SL3 TURRET PROBLEM
    Quote Originally Posted by bbrreid View Post
    thanks
    One of the clamp/unclamp switches is not working, or one is stuck closed.
    Jan 2004
    185
    Quote Originally Posted by underthetire View Post
    Thank you for the reply,can you please point me in the direction of the switches, are they the relays on the cabinet door?
    BR
    Jan 2004
    185
    Just an update on problem also looking for any manuals on the Mori Seiki SL-3
    Turret sitting on position 1 selector switch on 1 when pressing green turret button the turret moves forward then back but does not index, we have fitted 2 new relays (my4 24v) to CR17 and CR18, also the green light stays out until I switch off and reset power to machine. before this happened it was working fine until it started indexing without stopping(with a banging noise) or pressing the index button, the turret is a little bit out of line and we dont know how to slacken and fix
    BR
    Jan 2015
    42
    Check the limit switches on the back side of the Turret itself
    Jan 2004
    185
    Quote Originally Posted by ncbobbys View Post
    Thank you will do
    BR
    Jan 2004
    185
    Problem fixed by ex Mori Seiki Tec. I know ,turret off, reset with dial gauge,reamed,dowels replaced,limit switches reset,now working.
    Thanks to all for help
    BR
    Jan 2015
    42
    Glad I can help.
    Let me know if you need anything else
  1. MORI SEIKI SL-25B TURRET INDEXING PROBLEM FANUC OT
    By ROHAN 1981 in forum Community Club House
    Last Post: 02-03-2014, 03:47 PM
  2. Mori Seiki SL2 turret won't unclamp
    By jolulank in forum Fanuc
    Last Post: 02-13-2013, 08:51 PM
  3. Mori Seiki SL3B Turret
    By JohnnyTurn in forum Mori Seiki lathes
    Last Post: 11-04-2012, 05:57 PM
  4. Mori Seiki DL-150 Turret ref.
    By rai in forum Mori Seiki lathes
    Last Post: 07-12-2011, 10:10 AM
  5. Mori Seiki SL 0H turret
    By tapserv in forum Mori Seiki lathes
    Last Post: 01-20-2008, 08:01 PM
