I recently picked up an ebay 40W cutter and am having a problem with CorelDraw/CorelLaser. The cuts don't accurately reflect the placement of objects in the drawing I'm trying to cut. Furthermore, object/cut positioning seems to vary based on what other objects are also trying to cut. It's as if CorelLaser is misinterpreting the drawing as it heads to the cutter.
Here is my specific example that may help explain:
I'm trying to cut slots and holes in to a base (of 1/4" plywood). The slots mate with other pieces using t-slot construction and the holes match standard, perforated 1.5" angle iron. My workflow starts in FreeCAD and then I export the face as a SVG and open in CorelDraw/Laser. I confirm that all the measurements are accurate in Corel, along with line widths and black color.
When I go to cut, the holes don't match the angle iron holes and can be significantly off on both the X and Y axis, The slots are also improperly cut with the distances changing from the drawing.
These cuts are consistent from run to run, seemingly eliminating hardware issues of the X and Y axis. However, if I change parts of the drawing, say by deleting the slots while leaving the holes as-is, the unchanged objects will now cut in different positions than before.
I've tried including some reference objects, such as small boxes in the upper-left and lower-right corners but so far, the deviations from the accurate drawing are not predictable, even though consistent from run to run.
I've searched the forum but I haven't seen anyone with a similar issue. Can anyone help point me in the right direction?
Thanks!
I'm using:
CorelLaser: 2013.02.08.00289
CorelDraw 12 (Included with cutter)
