586,111 active members*
3,404 visitors online*
    Feb 2015
    28
    run from here issue
    so today i was using the run from here command (r.f.h) and when i tried to set the line to run from the program froze for a second
    when it unfroze it was ~10000 lines too early
    does this every time i retry it
    its very annoying as the program is quite long
    Feb 2015
    28
    Re: run from here issue
    any new info would be greatly appreciated
    Jun 2010
    4256
    Yeah, well, Gerry might well have better info, but I have never had any faith in set-line and rfh. Very iffy.
    Cheers
    Roger
  1. DFX issue
    By BBchevy396_ in forum Rhino 3D
    Last Post: 08-28-2011, 03:42 AM
  2. Cambam issue or Mach 3 Issue??
    By tracyranson in forum CamBam
    Last Post: 07-11-2011, 04:03 PM
  3. VF3 issue
    By driver1234 in forum Haas Mills
    Last Post: 03-11-2010, 06:11 PM
  4. Help with selector switch wiring issue (***actually a motor issue***)
    By BEDFORD in forum Charter Oak Automation Support Forum
    Last Post: 04-07-2006, 09:19 PM
  5. THC Issue
    By Aldoseri in forum CamSoft Products
    Last Post: 01-31-2006, 11:33 AM
