586,052 active members*
3,935 visitors online*
IndustryArena Forum > Other Machines > Other Machine Topics > Sunwin 4-axis CNC TB6560 instructions
    Jul 2013
    I am new in the CNC hardware area but have worked up CNC g-code for a 4 axis foam cutter where I used to work. I am retired now. I purchased a “Sunwin 4-axis CNC TB6560” kit through Amazon which came with 4 motors, power supply, board and some wiring. I am in the process of setting up my wife’s free motion quilting machine to do computer driven patterns that I have designed myself and created g-codes. There was supposed to be a CD with full instructions on how to hook up the hardware in the package. I received a mini-CD in the package but it appears that it is blank. I have tried it on several computers and they do not even see a CD. I know some of the connections but not all and whan to make sure that it is all correct before I power it up. My question is: Is there a web site where I can down load this information (preferably in English) or does someone have this information that I can get to complete my project for my wife’s quilter? Any information will be appreciated!!!
    Jan 2007
    1795
    with google I think you can find many documentation about..
    I give you the first two link, but I believe there are many yet
    http://www.cncgeeker.com/images/manu...eCNCGeeker.pdf
    three axis tb6560 cnc driver users manual PDF User Manual
    theres no real differences between 3 or 4 axis boards.. I mean as their setup..
    the tb6560 I think produced more than any other control..
    heres another about setting up in mach3
    ShapeOko.com ? View topic - TB6560 4 Axis Mach 3 Configuration
    Jul 2013
    I have not forgotten you. I have been busy in other things. The information you gave me links to was of great help. In the last month I have gotten busy and installed the board that I told you that I have and wired up the quilting machine, have installed two spring loaded motors with rigid belt tracks and we have done our first quilt after a struggle finding the right 25 pin parallel cable. It worked great and the pattern that I made worked wonderfully.
    My final hurdle is the relay that will turn on and off the quilting machine. right now I have a remote toggle switch that allows me to do this manually. One of the board ports has one pin location labeled spindle control and ground pins. This pin seems to vary in voltage from 2-volts to 5-volts when I click the button on the Diagnostics screen (Mech3" labeled "Spindle Toggle". What kind of relay/control do I need to complete this task when the program starts and stops? I would appreciate any information you can give me.
    Quilter47
    Mar 2008
    35
    Re: Sunwin 4-axis CNC TB6560 instructions
    Hi quilter47, this post just came up for me searching for wiring detail for my bob, but on my linuxcnc controlled milling machine.
    I'm posting here because when the machine is done, my wife is wanting me to make her a computer controlled longarm quilting machine, we have bought a older nolting hobby quilter, and I'm in the process of tacking together a rigid tubular frame to carry the cnc parts as her current wooden gracie is very flexible indeed to put it politely.
    I plan to use the CrossXY layout because it means only two steppers that I can mount on the static parts of the frame and generate all the horizontal axis from and control it with linuxcnc again and I've chosen the nolting because its simpler. For motors I want to use some larger steppers and dm860's because I have had a bad experience with exploding tbs6560 drivers already so they will be too heavy to move around in realtime so it suits that too.
    Just wondering if you have posted about your project and if I can glean any ideas from it, in particular how your going to do stitch regulation and deal with winding on between rows automatically, and what you are using as a cam processor for the patterns to produce the g-code, assuming we are talking about a longarm quilter on a frame.
  1. TB6560. Y and Z axis work fine but not the X axis
    By crimar in forum Stepper Motors / Drives
    Last Post: 04-16-2014, 01:45 AM
  2. 5 axis breakout board and 3 single axis drivers tb6560, not working
    By MROX15 in forum Stepper Motors / Drives
    Last Post: 11-06-2013, 07:34 PM
  3. Sunwin TB6560 5 axis driver and no manual!!
    By avirostick in forum Stepper Motors / Drives
    Last Post: 07-10-2013, 12:57 AM
  4. tb6560 5 axis
    By drago2012 in forum Stepper Motors / Drives
    Last Post: 02-18-2013, 06:24 AM
  5. 4 axis tb6560 need help
    By casi in forum Controller & Computer Solutions
    Last Post: 07-25-2011, 04:17 PM
