586,263 active members*
3,916 visitors online*
    Jan 2015
    23
    Make smoth starts and stops?
    Hello, in the motor tuning you can set the acceleration for start and stop of the stepper motors. I want it to start and stop pretty smooth so I set the values for that. But when I load a G-Code for example: g0 x0 - g0 x100 - g0 x0 the motor change the direction directly without a soft slow down and a soft acceleration... I want to use the g0 command because I am moving a camera to different positions and I want it go fast but I don´t want it to go to fast when it shall slow down and so. Is there any body who knows what to do?
    best regards: Flyingpickles
    Feb 2007
    505
    Re: Make smoth starts and stops?
    wrong answer
    Set your acceleration very slow and turn on Exact Stop mode.
  1. Need help!!!! plasma starts cut, then stops cutting after a couple inches
    By csalazar in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 12-13-2014, 11:25 PM
  2. Replies: 1
    Last Post: 03-18-2014, 09:42 PM
  3. Cut stops and starts along cut path.
    By jstrayer in forum PlasmaCam
    Last Post: 02-20-2010, 07:03 AM
  4. M-Stops and starts
    By shane.vella in forum Machines running Mach Software
    Last Post: 09-25-2008, 07:48 PM
  5. Too many "M00"s. stops and starts
    By mike hide in forum SheetCam
    Last Post: 09-16-2008, 12:04 AM
