586,058 active members*
3,826 visitors online*
Results 1 to 18 of 18
    Feb 2015
    9
    Bobcad drawing
    Hey, Just wondering if there's anybody out there that might be able to help me with a bobcad question. I have a customer that would like me to cut his name out of an old saw mill blade. How do I make a drawing that would work on that blade. I know I'm making this sound more confusing then it probably is. I'm still fairly new at this. How do I load that saw mill blade into bobcad so I can make the drawing up. Thanks. Robyn
    Apr 2009
    3376
    Re: Bobcad drawing
    Can you give us a "napkin" drawing and take a picture of it and post it here ?
    Feb 2015
    9
    Re: Bobcad drawing
    Take a picture of the saw blade
    Feb 2015
    9
    Re: Bobcad drawing
    Here is the saw blade
    Apr 2009
    3376
    Re: Bobcad drawing
    I am not sure what you are asking.Need as much info as you can provide.
    1st off are you Plasma Cutting or Milling ?
    What version of BoB are you using.
    How are you placing your text ? You can do it vertical or horizontal or circular,,,that is why I asked for a rough drawing.
    What kind of Font ?
    How big of letters ?
    You have to understand when you say "cut out" a name,,you have to imagine how that is going to look.Example,,an "O" is going to look like a hole,unless you somehow leave the inner part intact.
    Apr 2009
    3376
    Re: Bobcad drawing
    Notice the "O" will not work with this font,,,the center will fall out
    Feb 2015
    174
    Re: Bobcad drawing
    agreed! "tag" the "O" throw some lines up until it looks acceptable, keep the dropout centers there, I do it all the time, bobcad or other.
    Shoot me out the file (DXF, cad, etc.) Im not shy on format.
    Feb 2015
    9
    Re: Bobcad drawing
    Hey, Thanks so much for the tips. Here is a picture of the drawing. The customer wants me to cut those names out of the saw blade. I have always made my drawings up and put it in whatever shape I've designed. But I've never used a piece of metal that's already in the shape the customer wants. I'm not sure how to nest the drawing so that Mach 3 understands what it is I'm doing. Because when I go to nest the names without some type of border around the drawing, the nesting program of course nests each individual letter. Which won't work because I need to get these names onto the blade. I've always nested and then saved drawing to the Mach program. Is there a way to bypass nesting and do the drawing in Mach program.
    Dec 2008
    4548
    Quote Originally Posted by robyn123 View Post
    Whether you want to engrave or pocket the letters, you dont need any other shape added. Only ref. Just add a circle the diameter of the blade. Maybe make one for the hole in the middle. Place the text in the center and toolpath the text only.. the circle will be for zeroing the stock at the machine.
    Apr 2009
    3376
    Re: Bobcad drawing
    What version of BOB and is this mill or plasma ?
    You are only doing 1 piece ?
    Feb 2015
    9
    Re: Bobcad drawing
    Hey, Okay what you've said makes complete sense and I understand what you're saying. I've never had to do that so this is a first for me. I'll see if I can figure out how to do that. Really appreciate your help.
    Thanks, Robyn
    Feb 2015
    9
    Re: Bobcad drawing
    I'm using BOB V21. I am using plasma. And yes I'm only doing the 1 piece.
    Apr 2009
    3376
    Re: Bobcad drawing
    V 21 I never used,,so I am out.
    There are some on here that have,maybe they can help.
    Feb 2015
    174
    Re: Bobcad drawing
    I'm not sure this is going to work, new to this forum.
    OK! click the pic, v21, just drew it quickly.
    V21.2? yeah looking for my V21.5.2, found it! Not related just know there's an upgrade to this version. Don't mind me. I just keep talking. Sorry about that. I know...
    I now know how to upload pic's, lol, this will not end well.
    side bar: there is a whole qbasic proprietary language built into this thing, its tweakable till your sick of it. They hate me when i question them, FYI, it's there, they're not telling you. Want the list? It's not good but works.
    Feb 2015
    9
    Re: Bobcad drawing
    Hey, Sure I'll take a look at the list, if it might help.
    Feb 2015
    174
    Re: Bobcad drawing
    Fix your issue first, I will find the list an post them to you. It's off topic, just that version has hidden secrets, its looks like...
    '.250/.265 Spot Cycle (stu)
    Select Radius = ("3.175", "3.3655"), Point = FALSE, Line = FALSE, Arc = TRUE \
    , LinDim = FALSE, AngDim = FALSE, RadDim = FALSE, Text = FALSE, PGon = FALSE \
    , Group = FALSE, Solids = FALSE
    PointArccenter
    NCTool Toolnumber = 1
    GLOBAL NNUMBER
    GLOBAL HNUMBER
    dim WORKOFF as integer
    dim TOOLNUM as integer
    dim SPINSPEED as integer
    dim SPINDIR as integer
    dim COOLANT as integer
    dim SAFEZ as double
    dim SAFEZSTRING as string
    SPINDIR = 3
    COOLANT = 8
    TOOLNUM = 1
    WORKOFF = 56
    SPINSPEED = 1250
    SAFEZ = 1
    Ask Header="Stu's .250/.265 Lg. Spot Macro",Output,Cancel=canc,"Work Offset (55-59);0"=WORKOFF,"Tool Number;0"=TOOLNUM,"Spindle Speed;0"=SPINSPEED,"Spindle 3=CW 4=CCW;0"=SPINDIR,"Coolant 8=ON 9=OFF;0"=COOLANT,"Safe Z Height;0"=SAFEZ
    If canc Then
    Exit
    End If
    SAFEZSTRING = SAFEZ
    If InStr(SAFEZSTRING, ".") = 0 Then
    SAFEZSTRING = SAFEZSTRING + "."
    End If
    NNUMBER = NNUMBER + 1
    HNUMBER = HNUMBER + 1
    NCEdit Output, Line = CURRENT_LINE
    NCEdit Line = CURRENT_LINE
    txt = "/T"+TOOLNUM+" M6"
    NCEdit Line = CURRENT_LINE, Text=txt
    CURRENT_LINE = CURRENT_LINE + 1
    txt = "N"+NNUMBER+" M1"
    txt = "G"+WORKOFF+" S"+SPINSPEED+" M"+SPINDIR
    txt = "G43 H"+HNUMBER+" Z"+SAFEZSTRING+" M"+COOLANT+" (LG. SPOT)"
    Cycle1
    Macro23
    Run Macro="stuG81-250", Edit = FALSE
    UNSELECTALL
    Select Point = TRUE, Line = FALSE, Arc = FALSE, LinDim = FALSE, AngDim = FALSE \
    , RadDim = FALSE, Text = FALSE, PGon = FALSE, Group = FALSE, Solids = FALSE
    Delete
    Window2
    ViewRepaint
    It's not what your after, happy to send you crap, make the cake first, mess around with this thing later, my advice.
    Looping qbasic subs and mains, this is going to confuse your issue, please, the problem first. I have said to much.
    Feb 2015
    174
    Re: Bobcad drawing
    I am going to shut up now, I have confused the issue, I will get you those lists. Forget this and fix the PROBLEM!
    Sorry, my mind wandered off. I was wrong doing this to you.
    Dec 2012
    19
    Hello
    We provide the best lasers routes and plasma CNC machine. Need information. Please contact us
    Regards
    Casper
    Www.cncmetalcut.com
    Www.laser-solution.com
  1. BobCAD CAM V27 3D Drawing & Machining Sample
    By aldepoalo in forum BobCad-Cam
    Last Post: 11-30-2014, 05:20 AM
  2. BobCad Drawing to PDF
    By Shopboss in forum BobCad-Cam
    Last Post: 03-28-2011, 08:05 PM
  3. alibre express or bobcad v22 for drawing
    By dgalaxy in forum Uncategorised CAM Discussion
    Last Post: 11-24-2007, 05:16 PM
  4. Convert drawing for use in BobCAD-CAM 2007
    By bobby1 in forum BobCad-Cam
    Last Post: 04-24-2007, 06:10 AM
  5. Drawing in BobCad
    By Todd Price in forum BobCad-Cam
    Last Post: 10-25-2006, 10:43 PM
