The aluminum table is every bit as stout as a steel tubing table. They have units out in commercial shops cutting 3/4" plate on a daily basis. Only if you start to compare a welded table built with I beams and slinging around a huge gantry does the material start to matter. The 8020 rails that a lot of the builders use are extrusions and per pound are stiffer than steel.
