I've got an old Acroloc and I am machining a contour. I need to repeat this 6 spots and do a perimeter cut 1" deep in aluminum with a 3/8" mill. I could write a sub routine, but I can also use M99 Pxxx to go to a program line number. I can add an incremental Z move and just loop the cuts I've got programmed, but then I need a way to break out of the loop.
N10 contour 1
N100 end at start position
N110 Increment Z
N40 M99 P10
Any thoughts?
Thanks,
H
