586,234 active members*
3,126 visitors online*
    Feb 2011
    212
    building a new controller
    If you were to build a new controller and installing Mach 3 on it what would you choose and why.
    I'm thinking of building a fresh new computer to use with my Mach 3 to control my mill. The 1 I have now seems to have some issues and crashes . It is an old Del that I got from work to put in place of the computer my mill came with ( it died after I got it home )
    So if you could give me some solid info that would be great.
    Feb 2011
    212
    Re: building a new controller
    no input
    These are the requirements from the site
    •Desktop PC (Laptops are not supported) with at least one parallel port
    •32-bit version of Windows 2000, Windows XP, Windows Vista, or Windows 7 (64-bit versions will not work)
    •1Ghz CPU
    •512MB RAM
    •Non-integrated Video Card with 32MB RAM(Large G-code files, especially 3D files will require a video card with 512MB RAM or higher
    I would say that 90% of people building a new PC for Mach3 go with a modern PC and OS, and use an external motion controller rather than the parallel port.
    When using the parallel port, it's impossible to know how well a PC will work unless you've tried it.
    Also, I wouldn't try to run an old OS with a new motherboard. No drivers, and in some cases it just may not work well.
    If you want to use Windows 7, I'd get something modern. You'd probably need to add a PCIe parallel port card, which can be problematic in itself.
    I would probably say to either buy an old cheap P4 on Ebay, if you want to use the parallel port, or go with a new, modern PC and use a motion controller.
    Feb 2011
    212
    Thanks for the input
    The reason behind the parallel port is I want to replace what my mill has . I just want a direct swap out . As little new stuff as possible . . I may just replace a couple things in my computer and call it a day. I think my video card is going as my screen is starting to go out . Also u had an error on my screen right before my computer locked up .
  1. Help building a custom controller
    By Econdron in forum CNC Machine Related Electronics
    Last Post: 02-21-2014, 08:18 PM
  2. LPKF 91 Building new controller
    By swither in forum PCB milling
    Last Post: 10-29-2010, 08:50 AM
  3. Newbie - Building the 4X4 - Need Controller Help
    By tinygiants in forum Joes CNC Model 2006
    Last Post: 10-24-2008, 02:21 AM
  4. Want to start building a UHU Controller
    By simmo993 in forum UHU Servo Controllers
    Last Post: 07-30-2008, 02:52 AM
  5. Building a controller
    By wood_Workur in forum CNC Machine Related Electronics
    Last Post: 08-07-2006, 04:00 AM
