Hello!
I need some help with my machine.. Im engraving some plates with small text the text is one line and about 2,8 mm high.
I use engravetool with a tip that is 0,2 mm.
The software i use is Vectric Aspire, and the machine i have is a chinese LXM0609 with DSP controller..
So the small text is not in line, it is not straight. For example when i engrave: 000000 then mabye one of the zeros is 1 mm higher than the others..
But when i engrave some bigger text like 7 8 9 mm then it is fine!
Anyone has any idea?
