Ok I have a G0704 controlled by mach3. The spindle is wired to a C32 board via the 0-10Volt analog output to the G0704 DC controller. I have had the spindle at the max RPM with mach3 running the spindle and checked the 10Volt that needs to be coming out of the 0-10volt analog output on the C32 board. Everything seems to be working fine.
Now for the problem, The RPM on the mill (not Mach3) says it is doing 2450 RPM but I have no read out on the spindle RPM on the Mach3 screen. How do you get the info to mach3 to read the RPM?
Jeff
