586,035 active members*
3,712 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Multicam Machines > ATC-firmware for M24-5 board - looking for
Results 1 to 19 of 19
    Jan 2008
    35
    just replaced a M24-4 board with a M24-5 board
    transfer'd settings - flram.uc - from old to new board
    all's working so far
    until I tried to use the ATC
    now I remember, have to load other firmware into the board, did the same thing years ago for the old board
    the "new" board came from a 1 tool machine
    this is what motionmechanics displays :
    loading 7.05 K-STD build location 2
    in monitor mode :
    entered K520 monitor mode V507
    on the old board I had V4.28b and 5.67 ATC
    what do I need now ?
    who has it for me ?
    if anyone can point me in the right direction that would be great !
    Jun 2010
    463
    Re: ATC-firmware for M24-5 board - looking for
    Can you post a display of your files you have loaded now, and what type of machine is this board installed?
    Jan 2008
    35
    thank you for you're response, I was hoping you did :->
    not sure about what you're wanting to know or what more I can tell you
    pendant reads : loading 7.05 K-STD build location 2
    and I loaded the flashram from old board into the "new" one, al settings came through fine
    machine can be homed and run fine
    tool numbers in gcode are just ignored
    there's no ATC in pendant menu's
    it's an MG204
    what more can I say . . . .
    Jan 2008
    35
    anyone ?
    it's my guess I need to upload other software into the board like I did before
    what do I need, how to get it . . .
    thanks !
    Jun 2010
    463
    If you are using Jobserver to communicate with your machine.
    1. Exit out of Jobserver
    2. Goto start and goto Multicam, find motion mechanic
    3. Open Motion Mechanic, if you get a gray screen. Goto tools and select terminal.
    4. At the > you should see a blinking cursor.
    5. Type qc and enter
    At the point you should see all files and parameters loaded in tot the board.
    Copy and paste them on to the forum here, I will tell you normally the firmware and modules will not work with different revision of the control board ie M24/k520 rev 4 will not work with M24/k520 rev 5. Parameters will work and even those may have a few more parameters added to their list.
    Quote Originally Posted by keesfrees View Post
    in monitor mode :
    who has it for me ?
    Jan 2008
    35
    it's all in the attached file
    I'd like to see what you can make of it
    thanks again !
    Jun 2010
    463
    Just to verify this a Multicam MG series machine? Correct
    Jan 2008
    35
    Quote Originally Posted by MCPservice View Post
    Yep
    Jun 2010
    463
    Here try this file
    Attached Files Attached Files
    Jan 2008
    35
    a quick reply to thank you !
    It works, despite >10 warnings and 3 errors, wrongs set of flies, the others don't match ?
    anyway, looks good
    now I have > 10 tools :-)
    Jun 2010
    463
    Great if that files starts to give you problems...I have other version if needed.
    Keep us informed...
    Jan 2008
    35
    . . if that files starts to give you problems...I have other version if needed.
    Keep us informed...
    well, yes, it does give me problems, all sorts off
    no use going in to details
    so if you could upload another version PLEASE
    thank you ever so much !
    Jun 2010
    463
    Which version did I post last time.....can you give me a QC shot or tell me which version that you have...
    Jan 2008
    35
    this will do i believe
    what can i do for you ?/!
    Loader V7.05.17
    ATC V6.82
    MCIF V4.49d
    uCITO V2.09h
    Keypad M.A.30X 2666
    Controller :
    K520 Rev 5 MOT-SI M4 V0:2
    Interface M24 (ID 51)
    Serial Num #9127
    Speed 133MHz
    Memory 8M
    Step Delay ON
    Baud/Parity 19200 Even
    IP Address 169.254.253.253(255.255.255.0)
    Logic Voltage 4.930 VDC 0.000 VAC
    Mar 2010
    275
    Kees, great to see your still running the old MG!
    I cant really help with you with anything Rev 5 related, but that "Logic Voltage 4.930 VDC" looks problematic. My Rev 4 machine would be acting pretty flaky at that voltage. I'm actually pretty jealous of your ability to read that out right from the terminal! I have to break out the multimeter.
    My main machine: Multicam MG series (MG101) with original Extratech H971 controller, Minarik servo motors, Electro-Craft BRU-series drives, 4KW Colombo. Let's talk Multicam!
    Jun 2010
    463
    Boltz is correct on the voltage....you need to boost that to 5.9 as far as the other files...i have put 4 in this zip file, hope they help.
    Quote Originally Posted by Boltz View Post
    Jan 2008
    35
    result !
    took the latest, most recent one
    k5atc447.uc
    which is in fact :
    7.05.01
    no more error messages !
    extra functionality added, some of them a bit weird
    nevertheless, thank you !
    where do I send the cake ?
    Jun 2010
    463
    Glad I could help.....what other functions did you gain?
    Jan 2008
    35
    it's now possible to open the tool-chuck from the pendant
    wasn't high on my wish list :->
    this :
    home sequence -> load tool 1 -> warm-up
    works
    strange though, machine goes to the middle of the table twice before going in to warm up cycle
    this doesn't work
    spindle test -> error : "tool not loaded"
    tool 1 is loaded according to the display on pendant
    could any of this being changed by a setting ?
    I have an old flashram list, maybe something has been added, I haven;t look in to it to see if there are params added, I use a spreadsheet to do this kind of things
    it's nice to see the ATC tool-length set problem is done with now
    ( after setting the a new tool in ATC had to load any other tool and back to gain the right setting )
  1. pluto firmware
    By visky in forum LinuxCNC (formerly EMC2)
    Last Post: 11-11-2014, 12:54 PM
  2. DLL and firmware version
    By sml2010 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-23-2013, 10:46 AM
  3. PICStep Firmware V1.01
    By santiniuk in forum CNC Machine Related Electronics
    Last Post: 08-19-2005, 01:23 AM
  4. DMC-1700 firmware
    By Karl_T in forum CamSoft Products
    Last Post: 07-31-2005, 08:24 PM
