586,104 active members*
3,385 visitors online*
    Aug 2012
    36
    Question EMCO PC Turn 55 Homing
    I recently acquired a PC Turn 55 Lathe and PC including the control card and have been slowly getting it back to working condition. Spent a few days repairing the PC and got it up and running with WinNC v12.30 installed. The PC certainly seems to be communicating with the lathe ok, it recognises eStop and when the lathe is off for instance. I have some experience with building and running a CNC under both Mach3 and LinuxCNC so I'm not totally oblivious to how things should work; homing, gCode, etc.
    In WinCAM I have been going to the NC tab and this is where I'm stuck: the software has the alarm (7017 go for reference point) which after reading the manual indicates it should be homed, which is logical. We don't have the Fanuc control panel, just the PC keyboard, but for the life of me I cant figure out how to get it into the mode (zrn?) to allow jogging/referencing to home.
    I came across an description online that says to enter the mode press f1, when I do that however all we get is the help file popping up.
    I'm sure it's really simple to do but if anyone could help me out on how to get into the modes via key commands I'd really appreciate it.
    Thanks for your time,
    Apr 2002
    5003
    Re: EMCO PC Turn 55 Homing
    The C5 don't have the possibility of homing. If you want it anyway, you have to mount dial indicaters which you can use it after starting the machine.
    But, if you want to upgrade your machine to a modern control like mach3 or Linuxcnc you should remove the steppers and there drivers
    and change it to nowadays models. Thats not a really big effort and you increase the speed and precision of the machine significantly.
    Mar 2014
    44
    Not sure if you have an answer. In wincam there is a home button that looks like a bullseye. Click that and it should home.
  1. emco turn 120p with emco tronic ti control
    By rcjacob in forum Vertical Mill, Lathe Project Log
    Last Post: 03-26-2014, 05:01 PM
  2. EMCO PC Turn 50
    By bluepgt in forum EMCO Lathe
    Last Post: 02-02-2012, 10:27 PM
  3. No CRT Emco Turn 320
    By J_Copeland in forum EMCO Lathe
    Last Post: 04-24-2011, 05:03 PM
  4. Emco PC turn 120
    By spankyky in forum EMCO CNC Machines
    Last Post: 06-26-2010, 02:09 AM
