586,103 active members*
3,447 visitors online*
    Feb 2011
    20
    Cutting Board Options Recommendations Needed
    I have been doing a lot of research. I am in between laser engraver (yes a chinese one on eBay 40w CO2) or a CNC 3020 on eBay.
    All I am looking for is to be able to engrave cutting boards, I received one for our anniversary and it looks like it has a burnt finish but it is not just on the surface, its actually engraved into the wood and I would like to engrave anodized dog tags. I know lasers are more create image and print and the cnc may have more work to them.
    What would you recommend? I know the engraving space is very limited the cutting board we have is 10x18 inches but the engraving space is only 8x10... I saw someone that cut out the metal size of the laser engraver so fit larger object in. Would one of these "cheap" Chinese laser engravers do what I need on wood with multiple passes? Not looking for a machine that cuts anything. Just light etching.
    Jan 2008
    940
    Re: Cutting Board Options Recommendations Needed
    You would need a larger laser to do that size. A cnc router would be able to do both you would need a diamond drag bit to do real fine work.
  1. Tool Recommendations from CNC Router Store, 5/8 Melamine particle board
    By CNCRouterStore in forum News Announcements
    Last Post: 04-11-2014, 02:29 PM
  2. Breakout Board Recommendations
    By CJA Masterworks in forum CNC Machine Related Electronics
    Last Post: 04-09-2011, 03:22 PM
  3. Drive control board options for Mach3
    By CricutDude in forum Mach Software (ArtSoft software)
    Last Post: 03-21-2011, 10:10 PM
  4. 4th Axis options needed
    By Dave's_Not_Here in forum Techno CNC
    Last Post: 03-06-2010, 04:58 PM
  5. Replies: 8
    Last Post: 11-05-2003, 10:39 PM
