586,416 active members*
3,065 visitors online*
    Apr 2014
    3040t-dj cnc router z axis is backwards
    my z axis is backwards when I want it to go up it goes down. I was wondering if m ports and pins for my mach3 software is wrong? If so what is the correct settings.
    Apr 2004
    5741
    Re: 3040t-dj cnc router z axis is backwards
    You could try going into Config/ ports and pins/motor outputs and change the direction bit from high active to low active, or vice-versa.
    Andrew Werby
    Website
    Nov 2012
    108
    Just to double check -- the convention for Z is that the negative direction is down into the material, and the positive direction is up.
  1. 3040t-dj router spindle dont work brand new
    By rgroves in forum Chinese Machines
    Last Post: 08-16-2014, 02:39 PM
  2. Play in leadscrew nut on 3040T router
    By nickjb in forum Chinese Machines
    Last Post: 05-01-2014, 05:25 AM
  3. 3040T-DJ 3 axis cnc, need LinuxCNC help
    By FpvCnc in forum Chinese Machines
    Last Post: 04-03-2014, 02:24 AM
