Originally Posted by
scadvice
Unfortunately, I'm too far away based on your 'local requirement' or I could help.
Without seeing you print requirements and knowing the model of the Haas, it is difficult to know the scope of the job/s. I have done this sort of project for businesses a number of times, from one or two machines all the way up to and including budgeting and full production multiline turnkey setups.
Here are some points to consider:
1) Anyone doing this for you should have "some" experience doing this sort of thing. Making something like this 'turnkey' is not quite as simple as most people think.
2) Setup and fixturing needs to to be somewhat foolproofed to prevent crashes. So do the programs.
3) "Process Documents" covering any part or part families need to be written and proofed.
4) Job kits should be created along with whatever setup worksheets are needed. Sometimes these can be included with the "Process Documents" but that depends on the company's culture.
5) Quality Control is important even in it's simplest form. i.e. a few go-no-go gages, process sheet, and some basic inspection documentation.
6) Program and revision control.
7) Is this is production work, or 'build when purchased demand?' Each can create their own set of challenges and they need to be addressed.
8) I suspect the the setup and fixturing to be the most important phase of this with programing secondary.
9) Prototyping is generally means program changes.
Good luck in your quest and I hope these comments help you. PM call or e-mail me if you wish. I PM'd some contract information.
