586,103 active members*
3,456 visitors online*
    Jul 2012
    Ethernet Smoothstepper not working
    I am trying to get my cncrouterparts machine running using the ethernet smoothstepper.
    The machine was running fine on an old computer with a printer port going to a gecko g540. Then the computer died so I installed the ESS in a different old computer (p4 xp) without a compatible printer port and installed mach3 as I had on the old computer. I installed the plugin and all the settings step by step using cncrouterparts guide.
    The ESS leds show it is in wakeup mode until I start mach3. Then the leds show top green on, bottom green flashing around 5 flashes per second constantly. The bottom red led is on too. I could not find any info on the red leds in the manual or on the net. orange ethernet led is on, green ethernet led flashing quite a bit so it looks like its doing something.
    motors do not power up on the machine. toggling the charge pump switch on the g540 will make the motors power up. Toggling estop input active low allows me to jog in the mach3 software. The only communication I have been able to get is when estop active low is checked green and I click the reset button on mach3, the cnc motors make 2 slight quick noises, like the motors will power up, but they don't.
    any ideas of what is going on?
    Thank you for any help or ideas, I really need to get this sorted out soon!
    Jul 2012
    Re: Ethernet Smoothstepper not working
    Just to let anyone know that may have a similar problem. The red LED that was on indicates something is wrong with ESTOP. I swiched out my estop switch to a new one because I knew I had it all set up right and now it works.
    Jun 2010
    4256
    Valuable info re eStop LED, thanks.
    Cheers
    Roger
    May 2013
    4
    I am using a smooth-stepper to drive my gecko 540 and all is well with that portion. I am trying to control my laser by using spindle PMW for power level but cant seem to get port 2 to turn the laser on and off. It turns on manually OK, but I get no signal out of port 2 pin 17 on the smooth-stepper. Anyone have a suggestion. Thanks, Mike.
    Sep 2005
    371
    Quote Originally Posted by Mike.H View Post
    Did you ever get this resolved? I am having the same problem with a new setup.
    Scouring the internet and haven't found anything yet.
    Port 1 is working fine.
    Laser on Port 2 but nothing's happening
  1. Ethernet SmoothStepper - Mach 3
    By SteveSy in forum DIY CNC Router Table Machines
    Last Post: 09-28-2013, 05:49 PM
  2. help smoothstepper ethernet!
    By Cam4ge in forum SmoothStepper Motion Control
    Last Post: 04-30-2013, 11:58 PM
  3. DMM Drives and SmoothStepper Ethernet
    By vertcnc in forum Dmm Technology
    Last Post: 03-09-2013, 03:53 PM
  4. Smoothstepper (ethernet)
    By t300 in forum Novakon
    Last Post: 09-08-2012, 02:43 AM
