My first post & my first cnc build, i'm trying to build a machine based on CRP design, but i'm forcing a couple of problem due to shipping cost and taxes ....for some reasons i can't get the same part like they used and i will use what i can get here in israel. my problem is that my gantry is too much heavy (i plan to use heavy duty extrusion 100x200mm type MA1-9 from KANYA 17kg/m), also i already buy hiwin rails & blocks for all the axis (4x HGW25CC-ZA with 2 rails L=2500mm for X axis, 4x HGH20CA-ZA with 2 rails L=1600mm for Y axis, 4x HGH20CA-ZA with 2 rails L=350mm for Z axis). after gantry weight calculation i realise that it is too much heavy almost 100kg, is that a good or bad thing ?! i will use RACK&PINION system (i already have 3 unit of PRO rack and pinion drive nema 34) which motor should i use if i'm still want the gantry to be moved at 1000ipm or someting like that (stepper motor ) ? is nema 34 960 oz-in enought or i should go for 1290oz-in ?
thank u all
ASSADI
