Re: About to purchase a PRO4894, question about accuracy
I think you'll find that most well made hobby machines, like CNCRouterparts, are accurate to about 0.005". The number you are talking about, 92.25-91.75 would only happen if one of your stepper motors was slipping or something else could be wrong. As long as the machine is properly adjusted, you should see numbers parallel to each other within 0.005". If you want better than that, like .003" or even .002", you're looking at an industrial machine that's $500,000+. They use very accurate Ballscrews. And Don't think they even use Rack and Pinion system. I worked on a machine one year for a job I had, I can't remember the make, but it used all ballscrews and linear rails. It was accurate within 0.003". However, that was a laser.
I think you'll find that other factors will effect accuracy as well, like Cutter Diameter, Bearings or linear rails.
X²Design&Fabrication
www.x2df.com
