586,033 active members*
2,894 visitors online*
Page 3 of 15 1234513
Results 41 to 60 of 286
  1. #41
    Feb 2015
    36
    Re: Chinese CNC Syntec 6MA my experience
    Here is my latest video, might be useful to people just starting out, basically takes through the setup of material, latching machine coordinates and loading and processing a g-code file.
    Again this is for the Syntec 6MA control system
    https://www.youtube.com/watch?v=yk2TStKQBO4
    Cheers
    Lee
  2. #42
    Sep 2012
    228
    Can you send me the 2 post processors please?...
  3. #43
    Feb 2014
    42
    Hi Lee,
    Awsome videos! Thanks a lot. I´ll try your way later on this week. Also got a video from machine manufacturer and they got another solution to the Z height setting.
    What CAM are you using? I will try to get a post for Sprutcam.
    Cheers
    Daniel
  4. #44
    Feb 2015
    36
    Quote Originally Posted by Frankmali17 View Post
    Sure will do today
    Cheers
    Lee
  5. #45
    Feb 2015
    36
    Quote Originally Posted by dunderdunder View Post
    Hi Lee,
    Cheers
    Daniel
    I use Vectric Aspire mostly for the design software, it seems really good, the CNC I have is an XYZ P2 ATC machine with an 8 tool Carousel
    Cheers
    Lee
  6. #46
    Sep 2012
    228
    Dunder,
    How does your manufacturer suggest setting the z height?
    Is this video on YouTube somewhere?
    I have built my first machine and used mach3 to run it... with a Z touch off plate...
    It really suprises me that Syntec has a tool touch off mounted to the frame.. but no Z touch off plate like the ones we had in mach...
  7. #47
    Nov 2009
    314
    Hi Lee,
    Thank you for your post of our XYZ P2 ATC machine. We're very glad to know you running this machine so well,and totally hope this post will help more people who has trouble with this control system or other problems
    Through the video, I noticed the way you zero Z coordinate,why not use the auto calibration function ? though both way can do this,but I think auto tool calibration will be more conveninent. While it begins to change the tool holder,you can press F2 button on Syntec panel,then the cutter will come to the sensor after it finish changing. And this should be under the circumstance that you've set the tool calibration height in Syntec,you know what I mean ?
    By the way, we have 2015 new design P2 2040 updated right now,also with North American standard,see the photo attached. This machine equips with 8 tool magazine from Taiwan,THK guide rail,TBI ballscrew,Italy HSD 9.0KW ATC spindle, Syntec 6MA,YASKAWA servo motor and planetary reducer Japan Shimpo as standard,its Idle speed can be up to 50m/min, max speed up to 20m/min.Very stable under fast movement and offering you superior cut precision,capable of working in many industries such as woodworking,plastics,composites,non-ferrous metal...
    Attachment 282350
    Anyone who interested in this machine are welcomed to contact us.
    And thank you again Lee,hope you enjoy the P2 1530 ATC and keep us known about eveything regarding to this machine !
    Best regards,Mary
  8. #48
    Nov 2009
    314
    Hi Frank,
    We mounted the Z touch off plate on the frame bes it is very close to the tool magazine,it saves a lot of time after each tool holder is changed. Don't worry this way is very stable and has been proved very convenient while working.
    Regarding to the way of setting Z height,we recommend use the auto tool calibration function in Syntec panel,another way is the method that what Lee done in the video,set by manually.Both can zero Z coordinate.
    Cheers,Mary
  9. #49
    Feb 2015
    36
    Quote Originally Posted by EXLASer View Post
    Hi Lee,
    Attachment 282350
    Best regards,Mary
    Well Mary using the auto tool calibration the way you described did not work on my machine, it gave odd readings in the tool offsets when I tried to calibrate it this way I spent a lot of time trying to get it to work and in the end found adjusting the parameter and then using a pre determined tool gave me the most accurate measurements. Not to be rude but the Syntec manuals supplied are fairly useless, I realise that your company does not write the manuals or design and build the Syntec control system but using a reference tool means that tools are always the correct height and I know exactly where it will start cutting. Because the spoil board changes the height of the material from the base of the machine every time you machine it lower the use of a reference tool that every other tool is matched to means as long as I use my reference tool to align my material for the job every other tool is correct for height offsets without check each tool every time I change a tool which just makes the machining time longer
    Cheers
    Lee
  10. #50
    Feb 2014
    42
    I would like to know how the Syntec Tool calibration works. I believe that Lee´s way of using tool calibration works (try and error method).
    My machine supplier want me to set the tool sensor height and work table height diff into 3811.
    And then set the material thickness into external Z-height. Then it shall work according to them.
    I need to check both methods before comment them. But is the Syntec method different.
    I have seen a software button about calibration but have not tested it yet since I don´t tell how I shall measure the Z height.
    I´ll test both ( maybe more) this weekend.
    Anyone got a post for a 4 axis CNC router? 4th axis on the head and not rotating axis.
    BR
    Daniel
  11. #51
    Feb 2015
    36
    BR
    Daniel
    Maybe I didn't explain fully what I was doing in the video properly.
    I do use the automatic calibration for the tool touch off, all of the tools are set using that method. But....
    There are a few things to consider.
    Every time you flycut the spoil board to resurface it, the thickness of your material even if known changes.
    also if you calibrate all of the tools with reference to the no8 reference tool in the method I described in my first 2 part video then because this never changes then your tools are always at the correct height.
    Using the tool 8 reference method also allows you to use the tool to align to the corner or start position of your material. Then without having to measure or recalibrate the other tools you are instantly ready to start the job
    I maintain that once you have set up your machine with the methods that I described, the machines is faster to set up for each new job, more accurate and easier.
    The only time you need to reuse the auto tool is if you break or change one of the tool holders. Personally I have all of my tools set up not only in the machine but in the design software that I use with a tool database all positions and settings are also stored there. It makes the machine a lot faster to use and of course that makes it more profitable for my boss
    Cheers
    Lee
  12. #52
    Sep 2012
    228
    I see what Lee did, and know exactly why he did it that way... because like he said, the material thickness or spoilboard or whatever, can change.. this is a good way.
    My comment was, that it would be nice if there was a way to make a Z zero/touch off plate to add to the machines, just like in Mach3...
    I found some manuals about Syntec... but the poor English makes it hard to attempt to customize...
    - - - Updated - - -
    Can anyone tell me the difference between Syntec 6MA and Syntec 6MB ?
  13. #53
    Feb 2014
    42
    Hey Lee,
    Have you tried the software button (I think it is called) automatic tool calibration(not F2)?
    I´m not the same location as the Syntec system and can only guess what’s the buttons name are.
    There are a bunch of variables that the machine needs. You can choose 1, 2 or 3( 1 = one tool one work piece, 2 = one tool many work pieces and 3= many tools many work pieces). Then when I pressed start, the tool fly’s away and then I pressed stop since it did not seamed logic.*Then there is a button called something like “ auto Z-detection “. Ant if pressed when touching work piece it sends variables to the ext. Z-height.
    I will try them all.
    BR
    Daniel
  14. #54
    Feb 2014
    42
    Hey,
    6MB handles 4 axis and 6MA handles 3 axis. I got 6MB.
    Cheers
    Daniel
  15. #55
    Feb 2015
    36
    Hey Lee,
    BR
    Daniel
    Hi Daniel I tried the software button but the values produced from the process seemed to give strange values to the tool heights, combining this with my design software I could not get it to function as I would have expected. In the end and after speaking with the manufacturer and others I gave up trying to get this to all work together and settled on the method I now use.
    Cheers
    Lee
  16. #56
    Feb 2015
    36
    Here is my latest video, this is fairly basic, it's just about turning on the machine and then warming up the spindle.
    As most people will probably realise the large KW HSD spindles use ceramic bearings that warm up to work, to make these last longer it is a good idea to warm up your spindle in the morning, this is the procedure I use
    Video Link:
    https://www.youtube.com/watch?v=pSWHjBu6-9A
    Cheers
    Lee
  17. #57
    Feb 2014
    42
    Again great video. I will do a small program for spindle warmup to make sure it runs same every day.
    Now I have another wild question you might now something about. Or anyone else. Can I use cutcom registry for the tools in the machine? In my Mori Seiki I have 200pcs tool in the cutcom/adjust but only 20pcs tools in the tool changer. Then in the mill I set that tool 19 (in tool changer )uses cutcom/adjust registry 150. This makes life much easier when using CAM software and I can have much more tools ready in their holders without having to measure them everytime.
    Maybe I can call for T1 and then use H96 and it will pick tool one and use registry for H96-
    Maybe you have any ideas.
    Cheers
    Daniel
  18. #58
    Feb 2015
    36
    Cheers
    Daniel
    The do actually have a parameter that is set for the number of tools and positions to be saved in the controller, I would have to look it up to see exactly which parameter it is, I have a fairly extensive list at work
    But I think it is mostly used to match up with the tool changer numbers rather than having spare spaces that represent extra tools. I like the idea maybe you can manipulate the system to reflect the extra tools, there is a lot of flexibility amoungst the parameters.
    I can have a look on Monday and then post the relevant parameters if you like
    Cheers
    Lee
  19. #59
    Feb 2015
    36
    Another video, this one just on the basic Syntec controls, I realise this is probably not news to most people but I remember when I first started it seemed difficult to get even the most basic information on the controller, so I will keep plugging away
    https://www.youtube.com/watch?v=hMKr...ature=youtu.be
    Cheers
    Lee
  20. #60
    Feb 2014
    42
    Once again a great video! It´s logic and makes sense! What tool do you use for leveling your spoil board?
    Cheers
    Daniel
  1. My Chinese 6040 Experience So Far
    By kronick in forum Chinese Machines
    Last Post: 05-12-2018, 11:48 AM
  2. Replies: 4
    Last Post: 10-29-2013, 02:23 PM
  3. Chinese Laser Software Experience?
    By Smiffy6885 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-18-2013, 04:30 AM
  4. Who has syntec controller running there chinese atc
    By simso in forum Chinese Machines
    Last Post: 10-22-2011, 02:47 PM
