586,700 active members*
2,761 visitors online*
Results 1 to 15 of 15
    Oct 2006
    24
    Foamcutter Rebuild
    Hi All,
    Though I'd share my rebuild, and hopefully give/receive some ideas/opinions/advice.
    I made a cutter over 4yrs ago, from mdf. Served well! But time to make something better & more reliable.
    I pondered the options for the lower x carriages with the materials available, what I have, and what is cheap! These assemblies are the ones that seem to bind/stall the most, as they have to support the weight of the y carriages and their motors, and the hotwire bow if used.
    So, here's what I came up with.. fortunately these will be made using a cnc router, but it might be possible with normal tools with a bit of patience.
    Still working on the rebuild of the y uprights, thinking cheap sintered bronze bushings might work because there's not a lot of lateral force on them.
    I'll post pics of the rebuild if there's enough interest. Hopefully it will be much smoother and more accurate than the last!
    Any other ideas/opinions along the way would be great!
    cheers
    odf
    Oct 2006
    17
    Have a look at what moreil did at http://www.cnczone.com/forums/showthread.php?t=21812.
    He used linear bearings from vxb which are $US24.95 for a set of 4
    http://www.vxb.com/page/bearings/PROD/12mmLinearMotionSystems/LME12UU
    and I see that http://www.marchantdice.com in the UK also have similar available.
    Cheers MAL
    Oct 2006
    24
    Thanks Mal. Mikes machine is nice, but not that 'inexpensive'
    The cost of the linear bearings,plus the shafting, really starts to all add up.
    The mechanics of this design work out to 1/2 to 1/3 of the cost. The downside is a bit more building/assembly work.
    Seems to be a local shortage of the nylon/acetal material I was going to use, and to keep costs down, have gone back to doublesided 16mm laminated mdf. The laminate helps keep the mdf changing size with humidity, and only the edges will need sealing.
    All the parts have been cut out, so I'll post some pics soon of putting it together. Looks promising so far!
    Nov 2006
    11
    ODF
    how is the rebuild going ?
    should be cutting a test core tonight:banana:
    Rick
    Apr 2006
    312
    Yea, Just checking to see how the build is coming. Id like to revamp mine now that My router is done.
    Steve
    Oct 2006
    24
    Haven't been able to access my account on here for a while.
    Build is coming along very nicely. I've routed out all the parts, and have constructed one of the horizontal axis' and will spin it up soon. Pics on the weekend.
    Also,I was sick of being limited to using a third party interface and separate heat/timer boards. Over the last few weeks I've designed and built a integrated pc interface with pic based timer/heat functions. The great thing about it is that it can be used for both a cnc mill/router and a foamcutter at the flick of a switch.
    Here's a mockup of the basic layout. I've tried to keep the centre of gravity low by mounting the y stepper way down, as the uprights on the original cutter used to sway a little when changing direction. The first parts made from this model fit together perfect!
    Not sure how the bow will be mounted yet....
    Apr 2006
    312
    Did you CNC route your foamcutter. If so Id love to have the files. Looks great.
    Nov 2006
    11
    Dave will take some pics of the table & bow, will post later ( your set up is the same as Glenns )
    Rick
    Nov 2006
    11
    Here are some pics, The bow is supported from the roof with the cord with the bow at an angle to the table ,the wire is dropped into the slot on the y axis which is paper based phonelic ?(spelling(nuts) ) we can get the x axis's full travel with this set up (note this is not the bow we use as it had no wire in it but you will get the idea) it has to be quit wide so as to not fowl on the y axis.
    R
    Apr 2006
    312
    Do you get any slop on the Y axis. What I mean does it move back and forth like a tree in the wind? That was my problem on mine. I need to rebuild mine. Here is the pic.
    Attached Thumbnails Attached Thumbnails CNC 008_800x600.jpg   CNC 011_800x600.jpg   CNC 012_800x600.jpg
    Nov 2006
    11
    Quote Originally Posted by planekrazie View Post
    Its not to bad but we are only cutting 30/40mm high with a large bow that damps out some of the movment.
    Nov 2004
    26
    Extreme Foam Cutter
    I just finished my cnc foam cutter. Photos can be found at this linkhttp://www.depronlasercutting.com/foam.html
    I am running CeNeCe cutting at about 20
    Gary Guidi
    Depron Laser Cutting
    Jan 2007
    4
    Foam cutter rebuild
    This will Test your knowledge of French. But the design is simple and elegant. Also appears to be very inexpensive using Skateboard bearings. I figured I could use 2 pieces of 1x1 hollow aluminum bolted as longtitudinals with a few 1x1 spacers to give a 1x3 beam in lieu of his 15x50mm hollow section which I can't find a close size locally.
    oops forgot the link.
    Link is
    http://grenadeindoor.modelisme.com/cnccompact.htm
    Jim H
    Nov 2004
    26
    This cutter is for sale.
    Quote Originally Posted by gguidi View Post
    Gary Guidi
    I have decided to sell this cutter I have never used it. Anyone intersted please let me know.
    Gary
    Mar 2004
    1661
    Gary
    Use the classified section.
