586,115 active members*
3,232 visitors online*
Results 1 to 10 of 10
    Feb 2011
    21
    Part Quote - Steel Plate
    I need a part made. I need a one off "sample" to begin with, then 25-100 batches from there on. It doesn't need to be CNC machined, tolerances aren't all that important.
    3/8" thick steel, the cheapest easiest to machine steel will do.
    The more local, the better. If local, I can pay in cash. I'm located in the Litchfield/Hartford County area of CT. You can reach me via email at [email protected]
    Edit: It would help if I attached the images...
    Attachment 270910
    Apr 2013
    99
    Re: Part Quote - Steel Plate
    you do know it's likely to curl like a potato chip
    Feb 2011
    21
    Quote Originally Posted by LSM View Post
    Would you care to explain why that is? I'm not familiar with metal properties and machining (I'm a woodworker by trade). Is it because the thickness of the routed out sections only being 1/4"?
    Normally I would have had this done in aluminum, but I need the surface to be magnetic. There isn't any applied force on this plate at all.
    I'm in the early stages of design, so things can and will be changed.
    Feb 2015
    174
    CRS 1018, no big deal, it can be put "right on the money". It will tend to move a bit as it is cold rolled, compensate. "tolerances aren't all that important." why not have it right where you want it? It's doable. Is "doable" a word? lol I'm in Rhode Island but busy. I'll watch this thread to see what happens.
    Luck.
    Apr 2013
    99
    Stress in the steel removing that much form just one side might make it curl when you unclamp it.
    might have to straighten it if it needs to be nice and flat
    Apr 2010
    64
    How flat do you need these after machining?
    Feb 2015
    174
    Actually, you rough it out against some stops, "bounce" it around untill acceptable in a screw press. Throw the thing back in against the stop and finish it. Deflection minimalized for the final cleanup pass. Especially with cold rolled.
    Luck.
    Apr 2010
    64
    Yeah or stress relieve the material. There are a lot of options all of which cost more dependent upon whether he cares about flatness.
    Feb 2015
    174
    A thought, is cast or boiler plate an option here? In which case I'd go right at it, never worrying about any of this.
    Feb 2011
    21
    Change of plans. I got some quotes, the price was a a little off of where I wanted to be. I changed up the design and manufacturing process. Submitting a new RFQ. Sorry everyone, I hope I responded to every email though. Thanks.
  1. Quote needed for a part
    By PowerAaron in forum North America RFQ's
    Last Post: 02-11-2014, 03:25 PM
  2. Quote production part
    By millman52 in forum RFQ (Request for Quote)
    Last Post: 10-14-2011, 02:42 PM
  3. RFQ - Quote for cnc turning job, EN8 mild steel lot of 500
    By Sheepspeed in forum Employment Opportunity
    Last Post: 11-02-2010, 04:07 PM
  4. UK: Need a quote for small-ish steel plates
    By Philipf in forum Employment Opportunity
    Last Post: 04-05-2010, 08:02 PM
  5. 3 part quote
    By turmite in forum Employment Opportunity
    Last Post: 03-26-2009, 06:01 PM
