586,121 active members*
3,061 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Need Help Finding Replacement Fuse
Results 1 to 6 of 6
    Aug 2007
    24
    Where can I find a replacement fuse for a Bel 1A 250v circuit board fuse. Other markings on the fuse are <ps>E, Jet, T12A 250v
    The fuse is rectangular measuring 0.326 x 0.158. The pins are 0.024 dia. The center line of the two pins is 0.222.
    This fuse plugs into a break out board which is no longer serviced. The bob is powered with 5 v dc.
    I have had no luck at the various web sites I have been to.
    Any help would be appreciated.
    AJ
    15362
    Re: Need Help Finding Replacement Fuse
    Quote Originally Posted by AJA View Post
    This could be a good place to start
    Fuses | Circuit Protection | DigiKey
    Attached Thumbnails Attached Thumbnails Bel Brick Fuse.pdf
    Mactec54
    Aug 2007
    24
    Can anyone tell me if this is a slow blow fuse?
    Feb 2015
    74
    <ps>E, Jet, T12A 250v <<<=== well <ps>E Jet is the Certification and T12A tells me it is a 12 Amp Slow Blow 250 Volt rated.....
    http://www.socfuse.com/products/pdf/CatalogE.pdf <<=== I'm sure you can find one at digikey, this PDF tells a lot about fuses
    Aug 2007
    24
    Lonewoff55,
    Thanks for the link, it explains a lot-- I thought the <PE>E had more significance when finding a fuse..
    I guess the "T" should have been obvious -- meaning time delay.
    I sure appreciate the help, The filters at digikey are pretty confusing to me.
    Thanks much for your help,
    AJ
    Feb 2015
    74
    Lonewoff55,
    AJ
    Your Welcome ... Now I did notice in your original Post you asked for a 1 Amp fuse, but the numbers off the fuse say 12 Amp...
    I understand how Digikey's filters can be a bit CornFusing, I've been dealing with them since the mid 80's and trust me they have Grown over the years.
    As far as using filters you can go to the digikey home page and use the catalog from the Beginning then select Protection Devices and IF you must have a Bel Fuse on the left you can select Bel as the Vendor to search thru.
    in case you don't know you can DL their complete Catalog in PDF format here is the link:
    Digi-Key Catalog US2011
    it's from 2011, the latest they have in PDF
  1. Finding skilled workers like finding Moby Dick
    By Shaun81slc in forum Canadian Club House
    Last Post: 10-31-2013, 02:21 PM
  2. 600V 4A Fuse a replacement for 400V 4A
    By Skiroy in forum CNC Machine Related Electronics
    Last Post: 09-04-2011, 06:12 PM
  3. Replacement for screw in fuse holders, F12 etc.
    By Mr. Technical in forum Bridgeport / Hardinge Mills
    Last Post: 07-20-2007, 01:57 AM
  4. Help with finding a replacement stepper?
    By Brokengears in forum Stepper Motors / Drives
    Last Post: 11-05-2005, 07:57 PM
  5. Help with finding a replacement stepper?
    By Brokengears in forum Servo Motors / Drives
