586,117 active members*
3,606 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Adding 4th axis (rotary) to a 3 axis cnc router
Results 1 to 7 of 7
    Mar 2014
    1131
    Hi all,
    I have a 3 axis cnc router. The driver card I am using is 4 axis cheap TB6560. It is connected to computer via parallel port. 3 axis for X, Y, Z and one is the slave of Y. So I have no free port for the rotary axis I want to add.
    To add the rotary axis do I need to buy a new 5 axis driver card or a single axis driver and connect it somehow to the main card?
    Best,
    Suat
    Jan 2009
    16
    Re: Adding 4th axis (rotary) to a 3 axis cnc router
    Hi - Is the rotary axis to be used as a substitution for another axis? If it is, couldn't you just plug it into the unused axis driver? You would probably have to setup another machine profile and start in that. You will probably have to buy a 5 axis card as you will need a breakout board to run the single axis driver. I was going to add a rotary to mine but on the latest one I built, I don't have the clearance under the gantry. I've now decided to build a dedicated machine for it. If you are going the TB6560 route it might be cheaper to get the individual drivers (around $10 ea on eBay) and a breakout board. I've got less than $40 in this one. Click image for larger version.
    Mar 2014
    1131
    The laptop I'm using for the machine is very old but it does have a parallel port and a PCMCI expansion slot so I can add another parallel port for the rotary axis. Like you are saying all I need is a breakout board and a single axis driver. I'll go cheap for this and use what you use.
    Thanks for your help.
    Best,
    Suat
    Jan 2009
    16
    Hi - I don't think you can combine the ports. You will have to assign a different port address for the expansion card and I think your operating system (CAM program) will only accept one. You already have the A axis pin inputs in your 4 axis card. Are you going to be using both the X and Y the same time as you're using the A or rotary? If you're not using your Y, just position the Y and unplug the slave (A) and plug it into the rotary axis. You will have to setup a separate machine profile in your CAM program but you will have to do that anyway. I think that would be your easiest and cheapest way to do it. -J
    Mar 2014
    1131
    I'll use all 4 axes (physically 5) at the same time.
    I'm using Mach3 as CAM. It allows to use two parallel ports. Nice feature.
    Best,
    Suat
    Jan 2009
    16
    Ok, I was thinking like mine, the A axis is used as a lathe rather than a rotary table. I only use three axis for that. I looked at my Linux CNC setup and it does have provision for a second and third port as well. Good luck! -J
    Mar 2014
    1131
    Thanks Joham.
  1. Replies: 1
    Last Post: 11-17-2015, 07:37 PM
  2. Replies: 26
    Last Post: 05-24-2014, 03:41 PM
  3. Adding a 4th axis to my router
    By ynnek in forum Mach Software (ArtSoft software)
    Last Post: 03-19-2012, 05:47 PM
  4. Adding a 4th rotary axis?
    By bfredo123 in forum DIY CNC Router Table Machines
    Last Post: 05-16-2009, 01:07 PM
  5. Replies: 0
    Last Post: 05-28-2008, 04:37 PM
