586,207 active members*
4,060 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > Sprutcam works okay with AutoCAD 2014?
Results 1 to 8 of 8
    Feb 2015
    12
    Getting ready to take the Tormach plunge and have decided on Sprutcam. Does this work well with autoCAD 2014? I've drafted 2 3d models in CAD but before investing any more design time before my machine shows up, wanted the boards advice on this CAD platform files uploading and working well with Sprutcam. I have access to AutoCAD 2014 at work, on my take home laptop. Before I go down the road of purchasing the mill, want to know if I need $ for a different CAD platform. Thanks in advance, Jim
    Jun 2014
    1780
    Re: Sprutcam works okay with AutoCAD 2014?
    I would think it would work fine as long as it will export .iges or .igs files.
    Sprut will import several file types, I only use the .igs files exported from Rhino 4, and it works fine.
    mike sr
    Sep 2007
    36
    I run Solidworks for CAD and use the SprutCam addin to export .iges, no issues to report. I have also programmed and machined parts for customers that were .iges and .step files that originated from Autocad, though I do not know what version. The only file issues that I have had are with .stl, but the 'sew faces' function in Sprut has always taken care of it.
    Jun 2006
    340
    I have used Solidworks exporting .iges files to SC7 (and its precursors) for five plus years without any problems at all. I am sure SC 8/9 will work just as well.
    Nov 2007
    2151
    IMHO sput works best with igs files. It reads the data / model features and generates good cam operations from this.. If your acad install can export to iges your set if not you will need a program that converts acad drawings to iges.
    Aug 2013
    980
    I use rhino and acadlt2014
    I use rhino to convert to iges for sprut
    If you can convert to iges you are gtg
    If not rhino is a pretty cheap yet powerful 3d program that can convert pretty much any file type.
    Congratulations
    AutoCAD can export iges directly. No need to convert anything.
    Feb 2015
    12
    It looks like you can't save as and select igs as a file type but if you enter the export in IGS command in the command prompt, it creates a file in the proper format. You have to click on the solid model itself before the export will execute. Thank you for the replies,
    Jim
  1. Replies: 10
    Last Post: 04-12-2014, 04:03 PM
  2. AutoCAD 2014 Service Pack 1
    By cncadmin in forum Autodesk
    Last Post: 10-10-2013, 03:41 AM
  3. Sprutcam and Autocad DXF
    By CNC-Dude in forum SprutCAM
    Last Post: 02-26-2011, 04:25 PM
  4. Solid Works or AutoCad???
    By bill south in forum Uncategorised CAM Discussion
    Last Post: 03-03-2006, 05:06 AM
