586,058 active members*
4,389 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > G code automatic homing in the middle of a program
    Nov 2012
    I am loosing a few steps in very long g-code programs. Is the a way to automatically return home (referencing the home switches) and then continue on in the program?
    Mar 2015
    Re: G code automatic homing in the middle of a program
    I'm not sure what you are asking, could you explain what you mean by "losing a few steps?" Do you want to remove a section of code and run the program without it, or do you want to start from the middle of the program? Or is it something else?
    A better option is to fix your machine so it doesn't lose steps, but if you really want to home it in the middle of the g-code, try using G28.
  1. Stalling in middle of CNC program
    By Lohmeyer in forum CamSoft Products
    Last Post: 02-26-2011, 02:47 AM
  2. Need to start in the middle of my program
    By tjatdrilltech in forum Haas Lathes
    Last Post: 09-13-2010, 03:28 PM
  3. VF-2 stops in the middle of a program!!
    By southernexplore in forum Haas Mills
    Last Post: 08-12-2009, 06:34 PM
  4. locked up in middle of program
    By nmn in forum Haas Mills
    Last Post: 03-31-2009, 03:33 AM
  5. starting from the middle of a program
    By panaceabea in forum Haas Mills
    Last Post: 03-28-2009, 12:31 AM
