586,111 active members*
3,652 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > three dead geckos sittin inna box
Page 1 of 2 12
Results 1 to 20 of 27
    i could use some helpfull thoughts , mine are a clouded if not smoked
    this is what ive gone and done to my gecks
    ive got some new motors and i wanted to connect one and try it using a separate 12v power supply for that motor (z axis),the other two are 48v, in my haste i connected the 12v+ to the common (WRONG) and the neg to the power neg(right) ,after realizing no axis will move i quickly powered down , ive got two blown fuses on the x and y axis that were running before this mishap ,after numerous times of trying to run the x and y,i stripped down to bare bones and rewired everything
    tryed running on three different computers and nothing ,
    the motors are getting power but won t move ,the led lites up on the driver ,
    is it possible that i could have cooked the logic in all three drivers , i can see smoking the one that was wired wrong ,but all three ?????????
    the only thing ive done differently is what i had already stated other than that it was a perfectly good running system , all the motor power and logic power were shared between the three drivers before this (two separate power supplies 5v logic supply , 48v motors supply )
    i was all exited to try my 770 oz motors ,this bites !!
    tomorrow i'm going to buy a new parrallel port cable and hope for the best , though im pretty much numb at this point
    any ideas ????
    Aug 2005
    1094
    Hi ,
    There is no connection between the step/dir, common inputs and the Gecko electronics. There are Opto-isolators in between.
    If I understand correctly, Connecting 12V to the Common terminal and Gnd to the Gecko Power Gnd terminal should not harm anything, UNLESS you 12 Motor supply is not isolated from your breakout board logic ground.
    The curent may have found a path from the common terminal through the opto diodes into your breakout board back to your power ground.
    My guess is that if the Geckos are damaged it is only the optos. If they are damaged, then your breakout board may also be damaged as well. Then there is your PC parallel port. Did you feed 12V into it?
    I'm only guessing though. I'm sure Mariss can give you a better explination.
    Good luck.
    Cheers,
    Peter.
    Jun 2003
    3312
    What point are you calling common? The isolated input 0V side that goes to the pc lpt port pins 18-25?
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Aug 2005
    1094
    The Gecko 'Common' terminal is the +ve suppy for the step/dir opto diodes. It is usually connected to +5V referenced to the PC parallel port ground.
    Then to step the drive, the step input is driven low.
    Peter.
    Do you want the good news or bad news first?
    1) Good news: The drives are probably healthy or at worst have a blown opto.
    2) Bad news: The PC's parallel port was very unhappy with what you did.
    Mariss
    Quote Originally Posted by Mariss Freimanis View Post
    Mariss
    not as unhappy as i am ,
    though i dont want to loose the pc , the drivers are my concern , pc's are cheap when bought used
    i changed the parallel port cable and the best i can get is a hiss from the motor ,i currently have it connected to my home pc ,which should send the signal ok
    how do i repair the opto ?
    so a simple phone call solved that last question i had , caught me off guard , gotta love that kind of service , definitely a well stood behind product
    i'll see if i m missing something here and verify if they are indeed tosted , then send them off for repair
    thanks guys
    Apr 2003
    348
    You could fix the pc with a PCI parallel port add in card
    i'll try that if i need to i'm hoping that its ok , there are some second hand stores around here where that stuff is a dime a dozen ,
    i'm going to keep my fingers crossed
    My answer was predicated on how the PC ground and your 12VDC grounds were connected. If both were tied together your PC took a hit. PCs don't do well with 12V applied to an output.
    The drives probably took a hit too but it's not that bad. It would have blown out the step/direction opto and the associated 200 Ohm LED current limit resistors.
    These are non-fatal damages that are best repaired here and we repair our drives for free. The damage is to surface mount components so it's better we do it having the right equipment. Send the damaged puppies back, we'll fix and return them to you.
    Mariss
    thanks Mariss
    we fix it free" are the words of a truely honoured product and company ,
    it isnt exactly something that rolls off of a lot of tongues
    i have one question , if the step/direction opto is blown would the motor turn at all , at this point it seems at least one of the drivers is turning one direction but slow and very rough and the motors hisses ,i have to test the other two ,but i had roughly the same results
    ive got a new port cable and the breakout board is bare bones basic
    i am using another computer to test it on so the signal should be good
    should the motor turn or should it not move at all
    OK,
    Quick test. Disconnect the main connector, get a multimeter and set it to Ohms. Connect a probe to COMMON, then measure COMMON to STEP, then COMMON to DIRECTION. The reading you want to see is 1.2K give or take 5%. Get that and the drive is probably OK.
    If not, send it back. It's 15 seconds out of my life if it's OK, 5 minutes if its not. 2 weeks out of yours though. 1 week to get here, 1 week back.
    We only do returns every Friday afternoon. Not enough returned drives per day to put on the trouble-shooting hat unless there's a number of them. Takes a week of returns to be worthwhile.
    Include a note describing the situation because I really hate mystery drives that show "no problem found". It's a lot of extra work chasing a problem that does not exist.
    Also it puts in a real bad mood and makes me really uncharitable if the bottom of the drive is covered heatsink goop I have to clean off before I can plug it into our really cool, computerized, pogo-pin equipped, pristine and spotless teststand. Be kind to me, otherwise I won't try so hard on your 5-years out of warranty drive.:-)
    Mariss
    Aug 2005
    163
    I can tell you one thing my next project will have gecko drives excellent product unmatched support!
    Jul 2004
    35
    I was on the fence with Gecko drives until I read this thread. I will be using on them on my project.
    i don t think they can be beat they really do perform nicely , worth every penny
    well things are looking better ,
    turns out the breakout board is toasted , i cut the parallel port cable and connected it direct to the drivers , i think one driver is ok , the other two turn one direction and sound bad with no movement when i try to change directions ,
    ive extinguished all posibilities except one ,i have to get an ohm meter tomorrow to test the direction , ive got one but its packed away somewhere underneath something in some corner ,
    OK,
    Mariss
    the tests show all three drivers as being 1.2k for the step and direction ,
    im going to get another breakout board and see what comes of it , not sure why im not getting direction to the motor on two of the drives , is there another test that i may be able to try ?
    thanks
    curt
    Geez, I kind of feel like a jerk mentioning the thermal grease thing now.
    Honestly, someone sends a drive back. We have to know why it failed. To know why it means we have to diagnose it to the component level and that takes 90% of the effort. By then you know what it takes to make well again. To me it seems miserly not to go the last 10% to actually fix the miserable thing, out of warranty or not. It makes eveyone happy.
    Mariss
    no worries bud i here ya
    i can t blame anyone for being ticked off being handed a greasey pile a crap,nothing rattles my day like starting into a job that someone else left when the machine table and trays are full of chip ,cant see the bench top because its full of crap from a job we ran last week ?? and no coolant in the tanks
    but seriously i just want to make sure they are cooked before i send them off i m not out to waste anyones time, im into a transition here so i have some time to kill before im into the new house then i'll sent them once im in,
    i never realized there was a warranty ,these things are only about 8 months old with fairly low usage ,im used to electronics being more or less on your own upon purchase , i suppose its because there are a lot of idiots out there connecting stuff WRONG , i think im to stuborn to grip that i blew it
    Mar 2005
    523
    we have all made stupid mistakes.
    usually too much on our minds ( other than what we are doing ).
    i shouldn't say this but one day i ........... ( i'm not going there man !!)
    but the good thing is, u got 1 drive that works.
    the better thing is, it will be fixed, and you won't have to get a second mortgage.
    so actually you are kinda lucky. :-)
    just come here and look at my scrap heap. :-(
Page 1 of 2 12
