hello everyone, I have purchaced a 1310 laser engraver from salecnc. It uses the coreldraw plugin for coreldraw 12. I have set up the machine and it cuts fine when I make a cutting file directly from coreldraw, but when I import a DXF file to corel it is like some of the lines gets thicker, it seems to be the straight lines that gets thick. The thicker lines are then cut multiple times and the rest only once. hope this make sence and that someone is able to help me.
-Colin
