In advanced dot measurement working fields, more and more people would like to accept dot projecting red laser alignment in practical dot generating working. This advanced dot measurement tool makes use of import 650nm red laser diode as its laser beam emitting source. It is not as bright as 635nm red laser with same output power range, but it has been enough for workers to obtain high accuracy dot generation on required working surfaces.
This advanced industrial dot projecting alignment laser tool utilizes import 650nm red laser diode and glass coated optic lens. Available with adjustable focus design, the projecting red dot is always available with high brightness and long distance beam visibility. Usually within 1 meter working distance, the red dot emitting from its laser beam targeting hold can be controlled within 1mm to 2mm. According to the screw part of laser alignment head, users can just obtain different size of red light spot on required working surfaces.
According to different targeting distance in practical use, users can always make free selection of output power so as to obtain ideal dot generation with required laser beam brightness. This industrial alignment laser tool has just provided great convenience for workers to make dot generation in laser marking, laser engraving, button positioning etc.
