586,089 active members*
3,893 visitors online*
    Apr 2006
    118
    Right table size for CNCRP PRO 48x48
    Got off the phone a while ago with Cory from CNCRP. Got lots of helpful info but once the call was done I realized I did not ask the proper size needed for the tabletop to support a 4x4 PRO. What is the ideal size?
    Jun 2013
    88
    Re: Right table size for CNCRP PRO 48x48
    Hey cstmwrks,
    It was good talking with you this morning. The ideal base size for a PRO4848 system would be 49" x 63" The V-Con system attaches to both sides of the extrusion rails so making sure the base is no wider than 49" is very important. The 63" dimension could be extended if you wanted to make a shelf/work surface on that side of the system. Here are a couple of good examples from our customers:Attachment 271620Attachment 271622
    Cory
    CNC Router Parts
  1. New vacuum table for CNCRP 4896
    By Hack in forum Avid CNC
    Last Post: 08-06-2016, 04:31 PM
  2. Replies: 19
    Last Post: 12-17-2013, 07:58 PM
  3. Looking to build Solsylva but 48x48
    By kkester1963 in forum DIY CNC Router Table Machines
    Last Post: 06-29-2012, 04:52 PM
  4. XY table design basics, linear ways to table size ratio?
    By Konstantin in forum Mechanical Calculations/Engineering Design
    Last Post: 03-13-2007, 06:21 PM
