Hello, I am attempting to machine a piece of hex stock with a round end, with the round end held in a 5C collet and I'm having issues with the piece rotating in the collet as I machine and was wondering if anyone had a solution to it.
Can you reverse the piece and grip it on the hex end in a 5c hex collet?
You need to really crank down on 5C collets with a sturdy pin wrench for them to grip. It also helps to lubricated the threads.
Regards,
Ray L.
Are you using the right size of collet? The grip range of 5c is only about 1/64-inch.
If you have a 3-jaw chuck, you can mount the round part in it and mount the chuck to your table with strap clamps or in a vise.
What size is the round portion of your part? How long is the round part? What's the material? Hardinge sells collets in .001 steps from 3/16 to 1 inch for the same price as their standard collets (I think).
You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
Typical 5C collets have a range of 1/64", which is about 0.015". My experience has been that is generally all minus - i.e. - a 1" 5C collet will have a useful range of 63/64" to 1". I spent a day several weeks ago sorting a box containing many hundreds of 5C collets of many brands, and they were all sets in 1/164" increments.
Regards,
Ray L.
Wow!
Where are the soft jaw people. Most the time you show something like that and its like cut a soft jaw to hold it.
On the other hand cadrhino said what I would use a 3 or 4 jaw chuck and plate to mount it on mill table.
If you have a properly sized 5c and 5c holder mounted to mill table then as ray said tighten it down good.
Hope this helps
md
Yes that's true, there is a reason that they make so many sizes and types of 5C collets as Steve mentioned. http://www.shophardinge.com/productGrid.aspx?catID=6896 there is much more to machining than the typical hobbyist experiences at home.5C is for precision.
