586,094 active members*
3,687 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Is there a standard size for work-holding fixture hardware?
Results 1 to 8 of 8
    Jul 2013
    608
    Good morning everyone,
    I am looking to add some alum. T-slots to my CNC machine's table along the edges to help me hold down some stock.
    I have a few options ranging from offerings from 80/20 extrusion (which are not ideal since they have a bit of camber along the "flat sides") or mitusmi and Minitec to woodpeckers alum pro rails.
    With all these different offerings and in order to make a good decision I would like to ask the community if there is a standard size more clamps and work-holding hardware comes in? Are there more 1/4" fastener types? 5/8? , M6 M8?
    This information would allow me to make an educated assessment of what I want to do.
    Thank you in advance.
    Apr 2009
    5516
    Quote Originally Posted by FoxCNC1 View Post
    The t nut size is usually dependent on the size (series) extrusion you're using. i.e. 45mm series usually has 10mm t slots.
    Jul 2013
    608
    Re: Is there a standard size for work-holding fixture hardware?
    thanks for your response and while I realize that, my question was more along the lines of what size Tnut do most fixtures use.
    May 2005
    3920
    There is no standards use but which you make ( to paraphrase a movie). Some companies promote T slots sized for toliet bolts but honeslty that can be limiting. If you go to 80/20 you can find Nuts, bolts, t-bolts and other goodies in a variety of sizes. My suggestion would be to use the largest bolt size possible for the hardware you are using. Keep in mind thought that large isn't always optimal.
    Apr 2009
    5516
    There is no standard. You use what fits the machine.
    Nov 2010
    520
    I've mounted some t-slots in my table. They work great. I milled up a few pieces of alum bar to fit in the slot, drilled and tapped for a 10-32 (if I remember correctly) and cut some heads of the bolts and lock-tited the bolt shaft in the tapped hole.
    Anyway here is a link to my build where these can be seen in a few pictures. I thought I had a post on just these, but I couldn't find it. I'll have to add that.
    http://www.cnczone.com/forums/cnc-wo...cnc-forum.html
    Jul 2013
    608
    Thank you guys. I am going to use some Tslot extrusion that takes a 10mm t nut
    Apr 2009
    5516
    If you try to use 10mm t-nuts designed for mill tables, I'd check the specs first to ensure they fit your extrusion. Otherwise it's probably easier to buy the t-nuts your extrusion manufacturer recommends and bolt your fixtures down with that. Some manufacturers make t-nuts for metric slots with SAE threads (I think Bosch does) so you can get stuff from Woodpeckers which uses 1/4"-20 threads....
  1. Please advice on this part's holding fixture design (Pics attached)
    By dalianharley in forum Tormach Personal CNC Mill
    Last Post: 06-09-2014, 05:40 PM
  2. Work holding options to hold thin round work? .024, .046 etc
    By KyleH2 in forum MetalWork Discussion
    Last Post: 06-07-2010, 07:22 PM
  3. Advice on fixture holding needed...
    By kprice1658 in forum Tormach Personal CNC Mill
    Last Post: 09-11-2008, 12:25 AM
  4. Haas SL-10 not holding size.
    By Mr.Xtreme in forum Haas Lathes
    Last Post: 05-21-2008, 05:12 PM
  5. Fixture for holding 31/32 Round Part
    By Smackre in forum Work Fixtures / Hold-Down Solutions
    Last Post: 06-03-2007, 02:24 PM
