586,058 active members*
4,270 visitors online*
    Jan 2012
    laser cutting aluminum and stainless back to back
    I recall at a previous job that we had to have a special yellow fire extinguisher if we were cutting aluminum and stainless in a production atmosphere . It may cause a chemical reaction and burn. Can anyone help with what the technical end of that? Tryen to explain it to the new safety guy and i got a doe in the headlights look.
    Feb 2009
    6028
    Re: laser cutting aluminum and stainless back to back
    We cut stainless and aluminum back to back on a daily basis. Never an issue for us. We do have downdraft dust collection. Been doing it for 25 years on the same co2 amada.
    Jan 2007
    599
    If you cut aluminum on a water table it can build up hydrogen gas underneath and go boom, have never heard that about stainless. all though there is different kinds of fire extinguishers available, i do not think you will benefit from one , if there is would be a gas buildup and it catches fire. It will be a very quick burn or explosion might move the sheet a little bit and that would be it. This would not happen on a downdraft table.
    edit:
    As a side note, the yellow fire extinguisher would have been for class D fires see here Fire class - Wikipedia, the free encyclopedia
    good for combustible metal.
    Jan 2012
    Well from what i was told years ago, it had to do with the laser sprayen the molten stainless on the aluminum slag. Some odd chemical reaction that collects in the dust collector and catches it on fire. The place i worked at burnt up 2 dust collectors.
  1. Back cutting a radius
    By bootdisc in forum UG NX
    Last Post: 10-16-2014, 11:57 PM
  2. Back cutting using Inverted tool
    By GGORRIE18 in forum Hypermill
    Last Post: 09-06-2013, 11:54 PM
  3. Aluminum blow back extinguishing cut
    By will_eng in forum Waterjet General Topics
    Last Post: 10-01-2012, 03:58 PM
  4. No Back To Origin For Laser Cutting Machine
    By omnicnc in forum Omni CNC
    Last Post: 09-13-2012, 06:20 AM
  5. Is it possible to laser cut back painted acrylic?
    By brooklyn_matt in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-29-2010, 09:03 AM
