This applies to Doosan MX machine.
For the care and maintenance of the Sandvik Coromant Capto tool holding system:
Note: The attached also has part numbers for the specialty tools needed when working on this unit.
Doosan Service Technician
[email protected] O:973-618-2461 M:973-803-9479
This applies to the Newer Doosan MX Series
MX2100
MX2600
MX3100
The ATC Recovery procedure:
Flow chart for regular turret maintenance
APC 300 Alarm on a lathe
How to reference home with an Absolute Position Coder (APC)
To address the Periodic Maintenance Alarm
tec2008-30.pdf shows how to clear the alarm
tec2008-46.pdf shows how to set/change the times and add/remove line items
B-Axis overhaul for an Old Style MX
MX2000
MX2500
How to Reset the Home position on ANY Doosan Machine.
(Note: for the exact numbers for your exact machine, you will need the Instruction Manual (AKA: maintenance and specification manual)
This procedure shows how to gather all needed information and apply it correctly based on what hardware the machine has and the reason why the "Reset of Home" is needing to be done.
How to maintain and calibrate the Q-Setter on an Lynx 220:
I don't know how else to answer your PM: as it won't let me...So I'll try this reply to something that you posted.
In this thread is the "How to reference any Doosan machine"
Call 973-618-2461 if you need to discuss further.
Originally Posted by Michael82
[email protected]
It is in the footer of every post I have...
...and you have emailed me before...
Where can I find the procedure for replacing the clamp/unclamp solenoid on a Doosan LYNX 220 LM
If you meant cylinder then this:
Attachment 429802
if you are asking for a procedure for "replacing the...solenoid" they don't exist within Doosan...
Here goes:
1. Verify the replacement is correct.
2. Take pictures and/or mark connections of previous unit.
3. Remove previous unit.
4. Install replacement unit.
5. Verify the connections are correct.
How to adjust reference position for the Power Mate Manager controlled ATC and Magazine of a Doosan MX machine:
